DMR-ES20 Flexible Recording
Discussion in 'Blu-ray & DVD Players & Recorders' started by etaf, Aug 28, 2005.
  1. etaf
    etaf
    Dec 1, 2004
    1,013
    +63
    i'm using the flexible recording and have a couple of questions
    1) I set up a timer record and set to FR - Do I need to set anything in the functions menu under flex rec - i have mine set to 8hours.
    so if the timer record is 2hrs 15min will it use the entire disk so max quality for 2hrs 15min or be adusted for 8hours???
    2) If I have say two timer records set up - how will FR work or know how to use the disc - will it optimise to the first timer recording and then be full for the 2nd timer recording.
    I'm recording to DVD-R's so only get one shot and would like MAX quality possible.
    3) If i record say an additional 2 mins at the beginning and an additional 5mins at the end to make sure the program is not cut off at the beginning or end- can I edit the begining and the end and then take-off {remove/crop} on a DVD-R before finalizing?
    thanks in advance for any answers
  2. etaf
    etaf
    Dec 1, 2004
    1,013
    +63
    anyone?
