DMR-ES10 - Which disks
Discussion in 'Blu-ray & DVD Players & Recorders' started by RHCP, Oct 30, 2005.
  1. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Which disks are the best to use for re-recording (overwriting)?
    I think dvd-ram?
    Will dvd-rw re-record?
    Which disks and what make and where is the cheapest?
    Cheers :)
  2. HMHB
    HMHB
    Nov 11, 2001
    27,582
    Nottinghamshire
    +6,511
    I use Ridisc RAM DVDs which I purchase from SVP and they are reliable and cheap. see here - they are £14.99 for 10.
  3. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Cheers for that! Great prices!
    What are the ones in a cartridge?
    Do you actually put the acrtridge in the dvd recorder? :)
  4. HMHB
    HMHB
    Nov 11, 2001
    27,582
    Nottinghamshire
    +6,511
    The ones in cartridges cost quite a bit more but they do mean that you never touch the surface by accident as the whole lot goes into the recorder. Having said that though, if you are careful with the others they won't be failing on you in a hurry !
  5. DRAMBO
    DRAMBO
    Feb 15, 2005
    157
    West Yorkshire
    +5
    Yes, you just put the Catridge in the machine for recording & playback. It's good for 100000 re-writes and has a 30yr shelf life. It costs £1.82 each from APRmedia. I have used catridge DVD-RAM discs for daily recordings for 3 years without any disc failure.
    :thumbsup:
  6. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Wow they're cheap, are they the ones in the cartridge?
    Wow, why so cheap?? :thumbsup:
  7. Rapid 17
    Rapid 17
    Jan 14, 2005
    904
    28
    +79
    I use DVD RAM and DVD-RW in mine. The Ram discs i am using are Panasonic and the -RW dics are Maxell. Both types have given good results. Geoff.
  8. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Can you use -rw for rewriting on a dmr-es10?
  9. Rapid 17
    Rapid 17
    Jan 14, 2005
    904
    28
    +79
    Yes you can. If you want to use them on another machine though, you have to finalise them. After doing that, if you wish to re record onto that particular disc, you will need to format it. Hope this helps. Geoff.
  10. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    im at work so cant read me manual, can you timeslip on a rw or just ram disc?
  11. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
  12. DRAMBO
    DRAMBO
    Feb 15, 2005
    157
    West Yorkshire
    +5
    That's by far the cheapest price for catridge DVD-RAM discs in the UK. This is only a guess, but perhaps APRmedia has too much stock and it may be a clearance price. It's cheaper than the non-catridge disc (in jewel case) which is £2 each. Both are Panasonic branded discs. I bought 5 more DVD-RAM catridge discs yesterday and I received them today. here's the link
    APRmedia.com
    :thumbsup:
  13. DRAMBO
    DRAMBO
    Feb 15, 2005
    157
    West Yorkshire
    +5
    No you can't timeslip on RW only on RAM
    However, before you finalise -R or -RW discs, you can use timeslip as an alternate to fastforward or rewind, to go to a specific point on the disc.
    :thumbsup:
  14. peter l
    peter l
    Drambo
    Looking at APRmedia now, but cannot see this item. Which one is it? Thanks.
    Peter
  15. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    +296
    No I cannot see it either on that link. Only Panasonic discs listed are the 4.7GB single and the 5 packs which are both non cartridge. The Verbatim 4.7GB type 2 is the one in the cartridge. I don't see any need to use the cartridge type tho. The non cartridge last just as long if you handle them with reasonable care. I now use the Ridisc make in spindles of ten for £14-95 from SVP.
    http://www.blankdiscshop.co.uk/acatalog/dvdram.html
  16. DRAMBO
    DRAMBO
    Feb 15, 2005
    157
    West Yorkshire
    +5
    It's the PANASONIC DVD RAM 4.7GB 3x (LM-AB-120-LE)
    here is the direct link
    APRmedia.com
    :thumbsup:
