DMR-ES10 DVD dimensions
Discussion in 'Blu-ray & DVD Players & Recorders' started by jm1, Sep 1, 2005.
  1. jm1
    jm1
    Feb 9, 2003
    371
    28
    +90
    The normal size for a PAL DVD is 720 x 576, but the DVD's made with my Panasonic DMR-ES10 are 704 x 576.
    Is this the norm for standalone DVD recorders?
    jm1.
  2. Zebadiah Twine
    Zebadiah Twine
    Jul 8, 2005
    56
    Recorders vary between the two. I was slightly peeved when I discovered that the Panasonic ES10 did 704 instead of 720 because I rip recordings to my computer and make my own DVD's and my favourite(very expensive)software doesn't support that size.
  3. jm1
    jm1
    Feb 9, 2003
    371
    28
    +90
    Thanks Zeb, what software do you use?, I'm using Womble Mpeg Video Wizard for editing and DVD-Lab Pro for Authoring, I'm getting excellent results :smashin:
  4. Zebadiah Twine
    Zebadiah Twine
    Jul 8, 2005
    56
    I use the TMPGenc range of tools for editing and was using Adobe DVD Encore for menus etc but it doesn't support the 704 dimension so I now use Ulead DVD Workshop. I did try the DVD-Lab, but I have to confess to having become a bit lazy and now prefer the GUI, drag and drop approach.
