DMR-E85 - +rw
Discussion in 'Blu-ray & DVD Players & Recorders' started by the_moose, Nov 4, 2004.
  1. the_moose
    the_moose
    Is there anyway you can watch a +rw disc on a DMRE85? Just made a disc on my +RW computer and sent it to the folks and they can't get anything on the screen.
  2. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,300
    +677
    I would have thought it would have been able to read the disk it just cant record to RW disks.Maybe your folks player doesnt like the brand of disks you are using.
  3. the_moose
    the_moose
    I am using TDK discs which I would hope are quite universal. Are there better brands?
  4. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,300
    +677
    TDKs are good ive not tried any RW disks with my E-85 but i use Ricoh +RW disks and these work ok on other dvd players i have.I will burn a movie to the ricoh rw and see if it reads it ok.
  5. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,300
    +677
    I tried a Ricoh DVD+RW in my E-85 and it played ok.
  6. jxp
    jxp
    May 26, 2003
    69
    I have played Maxell and Philips DVD+RW discs on my E-100 with no problems.
    When I make the disc on the PC I use the Disc-At-Once option.
    I believe this makes them appear as a read only disc.
    I don't know if you can also record them as re-writeable, this might be the problem.
  7. bobbypunk
    bobbypunk
    are you finalizing the disc, as the 85 won't play them unless they are finalized!
  8. MuffKing
    MuffKing
    In all honesty mate it's gonna be down to the recording format used on the disc rather than the disc itself. I know for sure that the Panny's will play +RW (until Philips change the recording format again), but if you are creating them on a PC then you need to make sure that the PC is recording them as MPEG2 footage converted to DVD-Video format.
  9. the_moose
    the_moose
    I will try that thanks. (yes they were finalised).
