DMR-E85 - HDD upgrade + mp3 juke box
Discussion in 'Blu-ray & DVD Players & Recorders' started by xaser1066, Sep 5, 2004.
  1. xaser1066
    xaser1066
    Hi there :hiya:
    A few silly questions about the Panny DMR-E85 which I am thinking of buying.
    Do you know if the HDD could be replaced with a larger one? Do you think there maybe a firmware limitation stopping the use of larger disks? Does the unit allow you to reformat the HDD and start from scratch?
    Can the DMR-E85 play audio only files from the HDD? Could these files be mp3's? I believe the audio portion of MPEG2 is mp3.
    Thanks, Jason :)
  2. tabatha
    tabatha
    Jun 9, 2004
    180
    16
    West Midlands, UK
    You can replace the hard disk with a larger drive BUT it will not do you any good as the firmware will not use the additional space.
    You cannot record MP3 files to the Hard Disk.
    There is a re-initialise hard disk function which I have never needed to use but which I assume will at least wipe the Hard disk. Whether or not it actually reformats and/or verifies the disk I do not know.
  3. get1a2get1a2
    get1a2get1a2
    you can record MP3 files to the Hard Disk if you conect another dvd player to the rgb in on the panasonic i have no problem
  4. Andyclockwise
    Andyclockwise
    Apr 6, 2003
    129
    Leicester
    +13
    I bought a Panny E-55 last week and am thinking of switching it to a E85 (RS have a 2 week change your mind deal, even though an extra £220 is a lot for an 85gig HDD, but I now realise I need the functionality. I was wondering if you can record to the HDD at the same time as viewing a DVD playback?
  5. apreading
    apreading
    Jun 28, 2004
    283
    +15
    Yep - only things you canot do are edit recordings or view another input source.
