DMR-E65 Green Picture on Component
Discussion in 'Digital TV & Video Players & Recorders' started by marko1480, May 27, 2005.
Tags:
  1. marko1480
    marko1480
    I have a problem with my current setup: Panasonic DMR-E65 / Sharp XV-Z200 projector and was looking for some help.
    I have the Panasonic directly connected via component and also indirectly via my Yamaha amp using S-VHS.
    When selecting the component input I get a green tinted picture and yet when I select the S-VHS input the picture is fine.
    Has anyone any ideas? :confused:
    Mark
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Is the picture 'a bit green' or like a B/W picture but green instead of white? Your PJ may be looking for an RGB signal on that input, or you may have the blue/red connections reversed somewhere. Start again, connect just the green and see if your picture is just black and white, plug in the other 2 one at a time and see the effect.
  3. marko1480
    marko1480
    Picture is a bit green. Will try disconnecting and reconnecting everything again to see if that makes any difference.
    Mark
