DMR E55 / PW6 Blocky Picture Problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by AxxxxA, Feb 13, 2005.
  1. AxxxxA
    AxxxxA
    Hi guys, can anyone help.
    History
    I have a panny pw6 plasma with sky digital and a recently bought panny e55 DVD recorder, I have installed it as per the recorders instruction i.e. scart from skys VCR connection to the recorders AV2 connection and a scart from the recorders AV1 to a RGB to VGA converter into my Panny pw6 VGA connection. all connections are turned on as RGB and I have used good quality Thor scart leads, fully fired.
    Now for the problem
    Since the recorder has been installed the picture quality seams to have gone down hill, all the images on screen now seam to be slightly blocky around the edges (not really bad but just enough to be annoying) it is especially noticeable on the shopping channels were the text is constantly on screen. I have tried playing with the settings of the TV an recorder but I cant get my head round what could be wrong as it seamed ok before the DVD was installed.
    Any help would be most welcome.
    Matt………
  2. JayCee
    JayCee
    Jan 20, 2004
    24,000
    Lanarkshire
    +2,617
    I know you state all connections are set to RGB but in reality you're not watching in RGB. The Sky digibox only outputs RGB via the Tv scart...which should go into the AV2 scart on the DVDR with it's AV1 scart going to the Tv
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    try SKY(TV scart set to RGB)>E55(AV2 set to RGB)>plasma (via component setr AV to component)
  4. AxxxxA
    AxxxxA
    hi, thanks for the reply, i have re-checked the cables and it is allready plugged into the TV scart connection on the sky box. being out put as an rgb signal.
  5. AxxxxA
    AxxxxA
    hi hornydragon.
    i assume by the last bit you mean change the component setting on the tv from rgb to component, if this is the case then all that happens is the screen goes pink. i dont have a component board on the tv only 2 scart boards and the standard vga connection which it is currently connected to.
