DMR-E55 Dolby Digital problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Zedmeister, Sep 22, 2004.
  1. Zedmeister
    Zedmeister
    Sep 9, 2004
    63
    11
    Hi there,
    I have a new Panny DMR-E55. When playing original DVDs that are 5.1 encoded, the "Display" option on screen reports that the disc is Dolby Digital 3/2.1ch. This is the case on all discs that I play. Is this a settings problem or is the machine broken??!!!
    Thanks.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,056
    Warwick
    +2,919
    Your outputting through the Optical out I assume? Check the settings in Functions/Setup/Sound
  3. laser
    laser
    Aug 1, 2004
    997
    Hartlepool
    +50
    This is normal. Most newer DVD players display "Dolby Digital 3/2.1ch". I have Pioneer DV-868 and a Pioneer DV-360 (top end and budget player) and both are the same. Next doors Sony GX3 recorder also displays "Dolby Digital 3/2.1ch".
  4. Zedmeister
    Zedmeister
    Sep 9, 2004
    63
    11
    Thanks, laser. Seems a bit strange, doesn't it? I know that it records its own stuff in Dolby Digital 2 channel, but it should at least display prerecorded DVDs correctly! Sound "appears" to be okay from my Yamaha AV amp (ie. I can hear the back channels) but I just want to make sure! I have sent an email to Panasonic Customer Support but have not had a reply. Does anyone have this particular model and can they confirm that this is normal? Do they all display Dolby Digital 3/2.1ch even with 7 channel discs? Must try a DTS title on it as well to see what it says!
    Thanks.
  5. Seanjackdan
    Seanjackdan
    This is totally normal . I have the DMR-E75 (the same player) and all the DD 5.1 DVD's I play show 3/2:1ch (which is 5:1 - 3 front speakers, and 2 rear) !!!!!
    When I play DTS DVD's,it shows "DTS".......
    Not sure what your issue is, but there is nothing wrobng here at all !!!!
    Sean !!!!!!!!!
  6. Zedmeister
    Zedmeister
    Sep 9, 2004
    63
    11
    My understanding was that Dolby Digital 3 means 3 channels - 2 main and the 1 subwoofer channel hence 2.1ch. Shouldn't a 5.1 disc display Dolby Digital 6/5.1ch? The way I'm reading the "/" is that it means either/or not plus. I could be wrong and what you say makes sense in a way but if you read most articles, it normally means 3 channels, set in a 2.1 configuration. Can anyone give the official Dolby labs answer to this?
  7. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    my sony amp comes up on the front saying 'dolby digital 3/2'
    now ive always thought that this means
    3 front channels, ie, the 3 front speakers
    and the 2 would mean the rears.
  8. SUPANORM
    SUPANORM
    Apr 19, 2004
    40
    Im pretty sure it means 3 front and 2 rear. I've got an E55 feeding into a Philips 32PW9618 and it says so in the TV's manual.
