DMR-E50 RGB Input Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by saspden, Dec 6, 2003.
  1. saspden
    saspden
    I've recently brought the DMR-E50 and it is very impressive. It puts VHS tapes to shame. The recordings made using LP is very good; far superior to VHS.
    However, I do have one problem. When watching cable through the RGB Input, a slight black dropout occurs on the recording when a bright transition goes to a dark scene or vice versa such as when a bright flash occurs. This doesn't happen when the input is set to composite scart. Has anyone else experienced this problem?
    Also, would I be better of using a second DVD player to transfer material recorded on a Ram disk to a -R disk or to transfer it to a PC before burning it to a -R disk on the computer
  2. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Make sure that input is set to RGB.I would try another lead
  3. azzo
    azzo
    Feb 13, 2002
    999
    Wokingham
    +9
    This has been discussed many, many times on the forums.
    Search for something like RGB E50 dropout or something.
    (It happens on the HS2 as well)
    I think the conclusion is that there is an incompatibility between the teleworst digbox (maybe other cable boxes too) and the panny recorders.
    There is no fix to this (or I have not found a fix to this) apart from use composite. If you try recording using another RGB source then you will find the problem magically dissappears.
    Azzo.
