DMR E50 Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by Johndm, Jun 28, 2003.
  1. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    I currently have a m/region Panasonic RA-82.
    Thinking of getting a E-50 now the price has taken a dive below £300. Does the E-50 have DVD-A capability (with direct phono outputs).?
    If not, I'm gonna have to daisy chain the old RA-82 through the E-50 to retain DVD-A (well the onscreen bits anyway)
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    I don't have any DVD-Audio disks but I'm fairly certain the E50 does NOT support DVD-A.
  3. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Does anyone know if the new E-60 supports DVD-A then?
    regards
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    The AVLand site states the E60 has "DVD Audio Playback (Stereo only)". The same goes for the upcoming E100. I don't know much about DVD Audio but I assume that means DVD-A is not properly supported.
  5. bobbles
    bobbles
    you would probably link the RA82 to the E50 anyway
    as the RA82 supports RAM
    you can record to RAM edit, play disc on RA82 and burn to -R
    I am sure you will find this very useful
    I do this with the S35, that does have the advantage of component connections to CRT though
    Does the RA82 have S-Video if so you could connect to the E50 via S-Video then still connect to CRT via scart
  6. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    You just convinced me to keep the RA-82..:D
    Never thought of those editing possabilities, 'kin well spotted!
    It will also solve my recording limitations, as I run my RA-82 through my Panny digibox scart to retain full RGB signals to my telly's RGB enabled scart input.
    So, the SCART chain will be.....RA-82 at end into digibox, digibox into E50, E50 into telly.
    Should now be able to record $ky on the E50, and trash those VCR's at last..:smoke:
