HenryHonda
Established Member
Hope someone with the technical knowledge of these machines can give a quick answer? (just off to RS to get one or the other to replace my BD-30)
- I don't need the analogue outs, as will be bitstreaming to my Denon AVR-3808A
- I know that the BD-80 can bring up a display with lots of info on the signal it's being fed - but does the BD-60 give anything at all?
- I know the BD-80 is touted as having better audio processing circuitry (but appears to have same D/A convertor) - will this only make any difference to analogue outs?
Basically, just wondering whether the extra £93 is worth it in my particular case
Thanks for any quick info...
