Dma Enabling
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by dan76n, Oct 11, 2003.
  1. dan76n
    dan76n
    May 12, 2003
    88
    australia
    hi all, still cant get capturing right. mark told me to enable DMA but my drives dont have a tick box in them to enable. i have a p4 so i would think it should be possible. can anyone help
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,255
    Rainham Essex
    +2,403
    I'm on a Win XP PC. Other versions of Windows will be slightly different, but should get you there:
    Open Control Panel (Start, Settings, CP)
    Double click on 'System'
    Click the 'Hardware' tab
    Click the 'Device Manager' button
    Double click on 'IDE Controllers'
    Double click on 'Primary' or 'Secondary IDE Channel'
    Click 'Advanced Settings' tab
    On the 'Transfer Mode' drop down menu select 'DMA If Available' for 'Device 0' if 'Master' or 'Device 1' if 'Slave'
    Mark.
  3. dan76n
    dan76n
    May 12, 2003
    88
    australia
    no good , i dont seem to have anywhere that shows dma in my drives.
  4. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    Perhaps you've got the Intel motherboard chipset? - on my motherboard which uses the Intel chipset (not the CPU) I use the Intel software called IAA (Intel Application Accelorator) and this seems to remove the DMA tick box option as described above, however the IAA software can be accessd from Programs and the software shows that DMA is enabled.
