DM31S speakers with Denon D-M31
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Nic H, Dec 13, 2004.
  1. Nic H
    Nic H
    May 29, 2004
    176
    +5
    Are these speakers any good for the bedroom or should I buy something else with the D-M31?
  2. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    There's nothing at all wring with them - they're made by Mission and badged as Denon. I think that the DM31 can be bought with speakers for about £250 now - and for £185 or so without? You could put the £65 toward bigger, better speakers - the ones that are offered with it are small bookshelf speakers.
    There's lots of people on the forums here that use the DM31 with speakers much more exotic than the DM31 itself! I use some 10yo Mission floorstanding speakers with mine. Do a search and you'll come up with the same question, or similar, asked before.
  3. converse
    converse
    Sep 21, 2004
    58
    They are decent, as "engaged" said made by Mission, they've had good previous reviews and would be ideal in a bedroom - save the cash and buy 20 quid or so of decent speaker cable to make them shine!
