DLP would seem best
Discussion in 'TVs' started by la gran siete, Jun 13, 2005.
  1. la gran siete
    la gran siete
    Oct 5, 2003
    24,778
    Deep in the bowels of sussex where the angloargies
    +1,767
    Having compared the three rivalling flatscreen formats I reckon DLP to be the clear winner. The other two seemed to be bright and garish whilst dLP ( Sagum in particular) just appeared more natural. Given that its relatively new format and with such competetive prices I'm wondering whether they may end up replacing CRT and drop in price even further.Only down side is the sheer side of the beasts.Not everyone wants such behemoths in their living rooms.
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,217
    103
    Nottingham
    +290
    Mind you if you you're not intent in hanging a flat panel from the wall a DLP takes up no more room and weighs less than an equivalent sized plasma display on a stand.
  3. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,600
    Aberdeenshire
    +182
    Looks like I might have made a switch from my original idea of a wall-mounted plasma.
    I have a 48" CRTRP at the mo, but it's well past it's best and I wanted something slimmer anyway. I was so close to buying a plasma panel but then I thought about screen reflections - and I found out that my room has too many windows to make a wall-mounted plasma with it's shiny glass screen watchable in daylight. So, as neilmcl says, if I'm going to put a big telly in the dark corner of my room, then it's going to be a dlp not plasma. And beside that, a 42" screen is just too small. :rolleyes:
  4. la gran siete
    la gran siete
    Oct 5, 2003
    24,778
    +1,767
    42" too small? :eek: :eek:
