DLP Video Scalers
Discussion in 'Projectors, Screens & Video Processors' started by Sorcery, Sep 16, 2003.
  1. Sorcery
    Sorcery
    Dec 12, 2002
    47
    Hi all,
    I am soon going to be purchasing an Infocus X1 DLP projector. I was planning on hooking up a cheap scaler to this - though through searching the forum I have found there appear to be 3 main candidates. Do people on here have any preference between the 3?
    1. Zinwell ProV
    2. VTB-100 XGA Scaler [from scancom] - this appears to be a replacement for the TV-4000 XGA Theatre they used to do and comes with a component set of inputs.
    3. CVP PC/HDTV Tuner [from lektropacks] - http://www.lektropacks.co.uk/product/technical.asp?dept_id=101&sku=590
    The third appears to support 2:2 pulldown for PAL which I am not sure if the others do...
    Which should I buy? :)
    Cheers,
    Nick
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,464
    Surrey. UK.
    +2,114
    Why do you want an external scaler? The internal Faroudja one does a pretty good job as far as I remember.
    Or do you want it for tv etc? A tuner via your video may do the job.
    Gary.
  3. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    I'm not an expert but I thought Faroudja DCDi was supposed to be one of the best deinterlacers on the market.
    I use a DVD recorder as a tuner for my pj. It is better than a VCR as it has s-video out compared to composite (although you may have rgb from the scart).
    I'll probably be upgrading to the new JVC DR-M1 as it will have component out (as well as prog scan as I don't have DCDi!).
  4. Sorcery
    Sorcery
    Dec 12, 2002
    47
    Oh...ok :)
    Maybe I won't bother then ;)
  5. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,464
    Surrey. UK.
    +2,114
    Try the projector first and see what you think.
    You'll probably be surprised at how good composite or s-video will look when connected straight into the X1 when feeding it an external signal from something like a video's tv tuner.
    Of course, for DVD and Sky you'll want the best possible signal such as RGB via component or Scart.
    Hope you enjoy the picture!
    Gary.
  6. Sorcery
    Sorcery
    Dec 12, 2002
    47
    Regarding the inputs on the X1. As far as I know these are:
    1 x Composite
    1 x VGA
    1 x SVideo [Component with adaptor]
    Since the projector is likely to be a fair distance from the AV equipment [need a cable of at least 10m] what do you think the best bet is going to be? SVideo?
    The DVD player I will be using with the projector doesn't have any Component outputs...
    Also what is the best way of switching between sources? At a guess I will be wanting VCR, DVD and Sky with the possibility of a couple of consoles e.g. PS2, GC etc.
    My original plan was to have 1 x 10m VGA cable from the scaler to the PJ but if I am not now going to use a scaler I will need to do something else ;)
    I don't particularly want to be buying leads which I don't need... :)
    Cheers,
    Nick
  7. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,464
    Surrey. UK.
    +2,114
    It doesn't hurt to run all connections to the projector - I have DVD, VGA, Copmonenet, composite and s-video. You never know what you may need in the future. ;)
    I use DVI from HTPC, VGA and component from a Skyworth DVD player (depending on what mood I'm in. :) ) and s-video from another player. Composite is there from the other player purely as a carrier feed for the amps on-screen display.
    If you need a switch box for multiple sources, then that's a different issue to an external scaler. So given the list you have, hopefully someone will suggest something suitable for you.
    Gary.
  8. Sorcery
    Sorcery
    Dec 12, 2002
    47
    Ok - supposing I am looking for the following then:
    1 x 10m VGA lead
    1 x 10m Component lead
    1 x 10m SVideo lead
    1 x 10m Composite lead
    What sort of price should I be looking at? I had a decent thread on cables and suppliers going the day before yesterday on here but it looks like it got deleted for some reason. :confused:
    I see Lindy come fairly highly regarded but what suppliers did other people use?
    For example is it worth paying £70 for Lindy's premium gold etc. etc. ? What is a good compromise on quality and cost? :)
    Cheers,
    Nick
  9. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,464
    Surrey. UK.
    +2,114
    I got my DVI from Lindys, and that was a good price. I wouldn't like to say if you'll see any difference between certain grades of cables, as I've done some testing with a range of cables and couldn't see any improvement - they did only range from £5 to £35 for the component cables I bought. Maybe spending £100 will make a difference, but I'm not willing to spend that much to find out - especialy if I can't see a difference. :)
    The reason I say put everything up there is because you never know what you may upgrade too - the X1 may be the first of a few, and although throw distance may vary a bit, you'll still be using the trunking for cables. Trying to pull a DVI cable in wasn't that easy depite my trunking being 4" x 2". I had just used vga because that's all I thought I'd be using as my first pj needed an external scaler to give a decent picture.
    I recon £30 a cable should be a good compromise for component and vga. CPC do various component, s-video and composite cables, so they could be worth a look.
    Gary.
    Gary.
