DLP or LCD
Discussion in 'Projectors, Screens & Video Processors' started by andyr300, Feb 10, 2009.
  1. andyr300
    andyr300
    Apr 9, 2006
    2,134
    +104
    I went into a i-fi shop last year and asked for a demo on their projectors.
    They only stocked DLP and I saw a mess of rainbows everytime there was any action.
    Is it likely that see it with one DLP projector and you will have the problem with them all?
    My problem is it seems DLP is 'better', people recommend them more!
  2. isayisay
    isayisay
    Dec 26, 2007
    903
    46
    +114
    I think its one of them some see rbe some dont,some can live with it,some see it less over time.I only see it if i move my head quickly to the side.LCDs i cant comment on apart from the chicken wire affect some claim too see.
  3. raigraphixs
    raigraphixs
    Jul 11, 2001
    65,463
    +25,787
    You may have to take your family and friends into consideration if your buying a DLP i assume, not fun if your the only one without any viewing problems. DLP is not your only choice anymore. Im no expert, sure someone will give you better advice.
    3LCD, the pannys are top notch and many have them on this forum, and no chicken wire in sight - AE3000 is the flagship model around 2k, so work your way down to your price range. Then you have the new expensive JVC's & Sony (cheaper price) (D-ILA/SXRD/LCOS) with their technologies - see links below for different types. It might help if you have a budget in mind, and someone can recommend a projector other than DLP.
    http://www.avforums.com/forums/dlp-...features-tutorials-updated-12-dec-2008-a.html
    http://www.avforums.com/reviews/Sony-VPL-HW10-SXRD-Projector-Review.html
    http://www.avforums.com/reviews/index.php?reviewid=9
    http://www.projectorcentral.com/panasonic_ae3000_projector_review.htm
    http://www.avforums.com/reviews/JVC-DLA-HD350-Projector-Review.html
  4. jacko5
    jacko5
    Feb 16, 2007
    1,198
    63
    +173
    DLP would be the display technology of choice for me if it was not for the fact that it causes eyestrain in my case. I had to give up a top range DLP projector for this reason. My next preference, and next nearest to DLP for filmic quality, is LCOS.
    I now have a SONY VPL-HW10 which is Sonys version of LCOS named SXRD in their case. It produces a very nice image and can be bought for around £1800.
    See Phil Hintons review of the HW10 in the AV Reviews section of these forums.
  5. Member 355391
    Member 355391
    Feb 15, 2009
    7
    4
    Tadley
    I see the rainbow effect all the time so the 1 chip dlp's are not any good fo rme. I did find the Infocus screenplay in80 very good and I didn't suffer from the rainbow with this one
  6. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    Not necessarily. Not all products use the same colour wheel design or operate at the same rotational speed. I see RBE on some product but not on others so in my experience it varies. The other potential issue is how the PJ is demoed. Usually with out of the box settings or max brightness and this can trigger RBE.
    LCD/LCOS PJ's also have issues such as motion smear/blur so it's choose your poison.
    AVI
