DLP Headaches
Discussion in 'Projectors, Screens & Video Processors' started by grooby, Dec 6, 2003.
  1. grooby
    grooby
    May 23, 2003
    57
    Whatton/Nottingham
    Hello
    Recently had a demo of the Domino 20. Great machine, want to buy.
    The only problem is that it left me with a headache.
    Do you get used to this or is it a case of once a headache allways a headache?
    Andy
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I also find single chip dlps a bit uncomfortable to watch (rainbows and headaches). Things have got better: the virtuoso is way easier to watch than a sharp 9000 ( nearly made me puke) for example. I also have some issues with CRT and plasma so I strongly suspect its either LCD or DILA for me regardless. You may find you can get used to dlps as a few people on here have discovered.
  3. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    When I firts demoed a DLP machine I ended up with really bad eye strain and a headache.
    However, a few weeks ago, I had a week long loan of the DLP based Sharp Z91E and I had no adverse effects like head or eye ache/strain and I really put some mileage on the bulb.
    Maybe just the demo set up?
    Hope this helps.
    Cap:)
  4. Operandi
    Operandi
    I had eye strain too after a Domino 20 dem. No matter how good a PJ it is, I have decided to leave it as I can't risk having problems with it in the future.
    BTW the dem was done using a Stewart screen with 1.3 gain so the gain might have been a bit high for this PJ.
  5. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,331
    +261
    I am susceptible to this too,but I had a demo of a domino yesterday and noticed no problem at all.The nec ht1000 gave me a real problem though.
    Phil
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    A very good thing about the D-ILA projectors is that you get pretty much 0 flicker on them due to the way the LCD layer in their panels works. It's well demonstrated by viewing through a Tv camera of some sort, like you get when seeing other PC monitors etc on Tv, and they flicker like mad, which doesn't happen with D-ILA.
  7. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I need to see a domino 30 before I totally go off dlp ( 20 is too low res for what i want). The sim HT200 (bog standard one) I saw a couple of years back was nearly livable with : saying that the virtuoso was more livable with.
  8. groovedigger
    groovedigger
    Nov 11, 2003
    28
    3
    Brighton
    same deal as when you first get a 32" TV from anything smaller methinks... you will adjust to it in time.
