DLP Convergence
Discussion in 'General TV Discussions Forum' started by NPM108, Feb 28, 2005.
  1. NPM108
    NPM108
    Nov 6, 2004
    109
    16
    Am curious to know whether all DLPs suffer from horizontal convergence issues at the top of the screen.
    I can only use the Sammy SP46 as an example, but when the screen is not in full widescreen mode and has the black colour bars at the top and the bottom, the top bar has a downwards sloping bend, whereas the bottom of the screen is dead straight (horizontal)
    A mate told me this was well documented on all DLPs....? Is this the case with the Tosh and Sagem models, perhaps owners of these sets can confirm?
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,786
    Somewhere in South Yorkshire
    +6,399
    First up - terminology:
    Convergence refers to the alignment of the three colours that make up a TV image. Poor convergence occurs when the three different coloured images are not in the same place on the screen. The result is coloured fringing around the edges of objects. Poor convergence can't occur on a DLP machine unless there is something very, very, very wrong with it. It's also referred to as alignment (in LCD projection).
    What you are describing is poor geometry. Poor geometry on a CRT device is quite common, and can often be improved with service menu tweaks. In the case of DLP RP devices (or LCD for that matter), it can only occur as a result of poor optics or some mechanical misalignment of components; it isn't electrical/electronic in nature and hence isn't a matter for a service menu tweak or other electronic setup issue. And I have to say that the majority of DLP RPs I've seen (in the likes of Curry$, Dixon$, Com€t etc) have had some bowing evident on one or more sides of the image.
  3. n00b
    n00b
    Nov 27, 2004
    317
    +17
    thanks for clearing that up, i too had the wrong idea of what it meant. i assume the mechanical misalignment of components can be corrected by an engineer.
  4. LV426
    LV426
    Jul 14, 2000
    13,786
    +6,399
    I assume so - given that they aren't all equally bad. However we may be straying into the grey area that is "manufacturing tolerance" here..... I wish you well.
  5. NPM108
    NPM108
    Nov 6, 2004
    109
    16
    Thanks for clearing that up, my mistake and good to know. The Bending effect isn't too bad, but was just curious as to possible reasons why
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,110
    As Nigel says it's due to optics. It is unlikely it's fixeable. In a rear pro it's more than likley that most manufacturers are using the same through length lens and, who knows, may be even from the same manufacturer. The lens s what will be creating the barrel distrotion. It is present on some fo the cheaper DLP front projectors too....it doesn't have to be that way....just you need to pay more money.
    Gordon
  7. Chris5
    Chris5
    Mar 21, 2004
    1,304
    63
    Herts., uk
    +184
    having said there are no convergence errors on DLP my green pixels ar misaligned from the red & blue by about 0.5 mm.
    Gordon, I assume u wont be able to help there when you come and ISF it next month.
    Chris
  8. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,110
    Chris,
    The misalingent you see is nothing to do with pixels not being converged. It's the same pixels doing all the colours. The difference will be in how the different frequencies light are refracted through the prisms and lens. It's not fixeable...
    Gordon
  9. Chris5
    Chris5
    Mar 21, 2004
    1,304
    63
    Herts., uk
    +184
    ok, I thought it might have been a timing issue with the wheel, you think this is normal then? I thought it odd that red & blue match perfectly, it is only the green that is out. it gives a green tinge to one side of white text, and purple to the other (you have to stand close to the tv to see it though).
  10. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,110
    It might be a chroma delay issue...The alignment of pixels is the same regardless of what colour is being displayed.
    Gordon
  11. Chris5
    Chris5
    Mar 21, 2004
    1,304
    63
    Herts., uk
    +184
    anyway Gordon, I look forward to meeting you soon.
    Chris
  12. LV426
    LV426
    Jul 14, 2000
    13,786
    +6,399
    Chromatic aberration. (Poor quality lens). At a guess.
  13. Chris5
    Chris5
    Mar 21, 2004
    1,304
    63
    Herts., uk
    +184
    but you would expect that to split red from blue even more than red from green, but it does not, red & blue align precisely
  14. NPM108
    NPM108
    Nov 6, 2004
    109
    16
    Guys,
    I had some time to spend this afternoon and have measured the bend effect.
    At the centre of the screen there can be a variance of between 0.5cm and 0.8cm more than on the left and right (although even these vary).
    As you can imagine nearly 1cm creates a noticeable dip down in the centre at the top of the picture when viewing widescreen dvd's which aren't full screen.
    When they are full screen and there is text near the top I've noticed that even that text bends.
    Given that I also have a noisy colour wheel issue on this set and that is only 1 week old, would you say I have a lemon and should return it? As this means not only do I have this geometry issue but also a excessively noisy colour wheel.
    Thanks.
    P.S. Will post pics when the camera's batteries are charged
  15. ducati748
    ducati748
    hi NMP108 , hi had almost identical problems with my tosh 46 . I phoned tosh support and they told me lines should be totaly straight and i should not be able to here colour wheel or fan over speakers - even at low volume . i had a comet engineer out who confirmed this and am getting a replacement set next week .
    imho i would get the set exchanged .
    anyway hope this helps
  16. NPM108
    NPM108
    Nov 6, 2004
    109
    16
    Well its hard to see the bending from these pictures but none the less I have attached them. The black background makes it hard to see the dip but its there!!
      Size:
      69.9 KB
      141
      Size:
      76.7 KB
      159
