DLP, 1280x720, £1500 or less. Does it exist?
Discussion in 'Projectors, Screens & Video Processors' started by Jumble Jumble, Aug 16, 2005.
  1. Jumble Jumble
    Jumble Jumble
    Jun 20, 2004
    37
    I'm currently looking at getting an AE700. My budget is £1500 including screen, and I'll be using the projector in a room that I will be able to get pretty dark (not black, but VERY dark).
    Is there a DLP in this price range I should be looking at as well? The 720 lines is essential because it is going to be used for a lot of HD gaming come November.
    I'll need to then demo both projectors to see if I can see the rainbows.
    Also, could somebody recommend me a screen? Are you supposed to use a grey one for LCD? I would like one about 6 feet wide, not electric or anything.
    The other thing is, getting the room dark. I'm thinking either heavily lined curtains, or black felt roller blinds. Sound reasonable?
  2. ZippyCat
    ZippyCat
    Aug 9, 2004
    573
    28
    +22
  3. spikerules
    spikerules
    The BenQ 7700 is around £1500, is a DLP and is HD Ready 1280x720 PJ. You can make a half decent screen yourself for around £25 for the time being! You wont beat the 7700 for price and performance. Trust me.
  4. lupinthe4th
    lupinthe4th
    Jun 20, 2005
    141
    +21
  5. DEANO-B
    DEANO-B
    Oct 15, 2004
    516
    Leeds
    When you demo an LCD PJ DO NOT project onto a screen with a high gain otherwise the blacks will be greys. If your going 'fixed screen' I would recommend a DIY job, I personally use fomex.
  6. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
    Do you have any links for Fomex ??
  7. Penfold73
    Penfold73
    Nov 3, 2004
    369
    +15
    If RBE is not an issue the 7700 is a no-brainer. Great value and excellent reviews. Screens are a bit over-rated IMHO. A flat, white wall is 80-90% as good as most screens. High gain screens are worth it I think, but you would only really need one if your projector was dim or you particularly like a bright image.
