DIYSG volt 8 .....loud?
Discussion in 'DIY Speaker & Subwoofer Building' started by grahamricho, Apr 12, 2019 at 7:33 PM.
  1. grahamricho
    grahamricho
    Oct 29, 2001
    938
    28
    York
    +34
    ive just finished my first set of volt 8s for surround side duties.
    I have always had dipole speakers so a very diffused sound, never had direct radiating speakers before. They are mounted each side of the listening position around 600mm higher than ear level.
    My room is only 3.2 m wide so your around 1.2 m from a speaker. They are the slanted front ones.
    Anyhow I set them up with my auto set up on my Arcam AV888 and played some clips I know and they were very loud and distracting, I got my SPL meter out and the levels were correct?
    Even when sat at the front of the room listening to the white noise from each speaker the volt 8 seemed really loud.
    I listened to some music concerts which are in dts and know well and instead of adding a bit of depth to the track it totally destroyed the front sound stage as if the volts were equal to the front speakers.
    In the end I've had to turn each one down by 2-3db and they sound great now, but before they were so loud....why would this be?
  2. grahamricho
    grahamricho
    Oct 29, 2001
    938
    28
    York
    +34
    I have not broke them in yet, basically finished them and hung them and listened so unless my SPL meter is only picking up the mids? And the bass driver needs a bit of time to warm up and that inturn makes the treble piercing?
  3. mattkhan
    mattkhan
    Nov 14, 2005
    9,456
    Beckenham
    +4,472
    have you measured the speakers themselves?
  4. grahamricho
    grahamricho
    Oct 29, 2001
    938
    28
    York
    +34
    With REW ? No not yet
  5. mattkhan
    mattkhan
    Nov 14, 2005
    9,456
    Beckenham
    +4,472
    q is whether they're wired up correctly
    SPL meter with noise based tones is reading a band limited pink noise signal so it is only measuring a portion of the frequency range (and an SPL meter can only measure that range anyway)
  6. grahamricho
    grahamricho
    Oct 29, 2001
    938
    28
    York
    +34
    The crossovers are right and everything else is right. What frequencies does the pink noise produce ?
  7. mattkhan
    mattkhan
    Nov 14, 2005
    9,456
    Beckenham
    +4,472
    how do you know they are right if you haven't measured the speaker?
    500Hz - 2kHz is the standard band limited pink noise for a main speaker
  8. grahamricho
    grahamricho
    Oct 29, 2001
    938
    28
    York
    +34
    Hi thanks
    I bought the crossover PCBs and it would be virtually impossible to put a component in the wrong place. All components are not polarity sensitive, I've double checked everything. The cabling to them is from the last lot and I even checked the polarity of the cable. So everything was spot on. But I will check with REW tomorrow and see the results.
    I will post them on here. It is strange how they take over the whole room. I even played some clips and sat away from them so they were not near me, sat near the main speakers and they still sounded loud?
  9. mattkhan
    mattkhan
    Nov 14, 2005
    9,456
    Beckenham
    +4,472
    People have still had problems with PCBs due to soldering, you might be a competent solderer of course :) nevertheless measurements don't lie so this is the best way to verify.
    As to why they sound loud, is it loud or harsh? Is it on certain tracks or with all content?
  10. grahamricho
    grahamricho
    Oct 29, 2001
    938
    28
    York
    +34
    I understand, I was a TV service engineer for 10 years in the he CRT days so have done quite a bit of soldering.
    They don't sound harsh, they sound very dynamic and I'm sure they would make a half decent main speaker in someone's system.
    They just sound too loud, if you heard them you would think they need setting up properly but get a SPL out and they are spot on.
    I was having a tweek last night and the mains level is +10 and to get the surrounds sounding good or matched with them they need to be around -3 which is not where the auto EQ put them. I think the eq put the level around +5. Thanks
  11. mattkhan
    mattkhan
    Nov 14, 2005
    9,456
    Beckenham
    +4,472
    Ultimately trust your ears so if they need to come down then pull them down a bit, will be interesting to see the measurements anyway
  12. grahamricho
    grahamricho
    Oct 29, 2001
    938
    28
    York
    +34
    Yes, thanks.
    I ain't used REW for a while is there a way to isolate each speaker to measure? I remember using it to measure the main speakers and setting the crossovers for the subwoofers etc but can you just isolate each surround speaker and play a test tone and measure? Thanks
  13. grahamricho
    grahamricho
    Oct 29, 2001
    938
    28
    York
    +34
    I will measure the other DIYSG htm 12s too. Would be interesting how they measure
  14. Ringnut
    Ringnut
    Jun 8, 2004
    1,659
    116
    Surrey
    +1,868
    What mains are you running? These are very efficient compared to most commercial offerings and do tend to give a 'big' sound that can dominate other commercial offerings IME. If they sound great when you reduce the volume by 2/3db that's all that really matters I'd say. I run mine at -2db to where the mains are set after running Dirac and that works perfectly for me.
    Edit: crossed posts, you have HTM12s so they should blend well. I'd just knock 2/3db off them and enjoy. :)
  15. mattkhan
    mattkhan
    Nov 14, 2005
    9,456
    Beckenham
    +4,472
    I would still expect them to measure similarly, particularly given they are paired with the HTMs (which are also efficient speakers with consistent directivity)
    depends how you connect, if using HDMI then you should be able to pick the relevant output channel and the signal will go straight to the specified speaker.
    the best way is to pull the speaker out into the middle of the room away from any boundaries and measure it directly from ~1m away but an in room measurement showing each speaker should be good enough to get an idea
  16. grahamricho
    grahamricho
    Oct 29, 2001
    938
    28
    York
    +34
    I'm using a old notebook for REW I think I connected a line out /headphone out to a input on the amp and then the mic is a USB UMIK-1.
    I've never connected it to my AV processor before, I used to take measurements for my hifi, and used to connect it to my hifi pre amp to a line in. Thanks
  17. grahamricho
    grahamricho
    Oct 29, 2001
    938
    28
    York
    +34
    Just thinking will I be able to use it in a 5.1 set up by just sending a stereo signal from note book headphone socket?
  18. mattkhan
    mattkhan
    Nov 14, 2005
    9,456
    Beckenham
    +4,472
    simplest solution is to swap the wires
  19. Luminated67
    Luminated67
    Nov 5, 2018
    727
    Ballymena
    +324
    It might simply be need to run them in properly but best to run a frequency swipe on them to see if some frequencies are showing too much gain. The human ear is most sensitive to the human voice and the frequencies around these so if there’s a lift around these then they will appear louder even if overall they are matching the rest.
