DIY VGA to Video RCA
Discussion in 'Cables & Switches' started by kiranp, Dec 5, 2004.
  1. kiranp
    kiranp
    Hi can anyone help me to connect a normal video out plug (RCA) to a 15 pin VGA (Pc monitor) port, so that the display on my monitor can be shown on my tv.
    A diagram or instruction of which pins to connect would be very helpfull.
    (am i on the right track to find which is the composite and ground pins on the vga port to connect to the rca plug, but does connecting the pins 1,2,3 create this composite connection?) CLICK HERE FOR PIN INFO
    Thanks!!
  2. lucidnightmares
    lucidnightmares
    Ok somebody correct me if I am wrong but first off RCA cables don't use RGB profiles like VGA does, and the highest res a non-HD TV can display is 640x480 pixels so VGA to RCA cables don't work. However, I do know that there is a company here in the states called AVerMedia that makes a convertor product for this task, but a desktop running at 640x480 is quite poor looking.
    Good Luck!
    Jon
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    but adding 3 100 ohm resistors in a star network would generate mixed sync
    from H and V. (or maybe 50 ohms would be better)
  5. kv5799
    kv5799
    Aug 17, 2011
    ha ha
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,555
    The Borders
    +3,026
    Is there a prize for resurrecting the oldest thread :D
    Joe
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    No, but there is a prize for - joining a forum, making your first post that resurrects a thread that is 7 years old and then making a comment (if you can call it that) of zero help to anybody :rolleyes:
    Welcome to the forum kv5799 :suicide:
    Mark.
  8. Jamie
    Jamie
    Jun 27, 2007
    4,614
    Harrogate
    +1,108
    Based on his Malysian IP address I'll hazzard a guess that the spammy signature will be along shortly. LEts see shall we :)
