DIY VGA Cable wiring diagram help needed
Discussion in 'Cables & Switches' started by jackuzi, Dec 18, 2002.
  1. jackuzi
    jackuzi
    Dec 3, 2001
    255
    16
    South Wales
    Well I have two 15pin D Connectors and some cable that will enable me to create a male to male VGA cable.
    Do I just wire it as a straight through cable ie. pin 1 to pin 1, pin 2 to pin 2 etc?
    Any info or links would be helpful.
    Thanks,
    Uzi
  2. Silent Fly
    Silent Fly
    It depends for what you need it for. If it is an extension cable in theory a 1-1, 2-2, 3-3, ... should work.
    Silent Fly
  3. jackuzi
    jackuzi
    Dec 3, 2001
    255
    16
    South Wales
    I wanted to make a lead to go between my PC and my PJ. Standard PC to VGA Monitor wiring I believe.
  4. Silent Fly
    Silent Fly
    I am 99% positive that the 1-1, 2-2, 3-3, ... will work. I would suggest you to call the PJ manufacturer. Just in case.
    Silent Fly
  5. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Uzi,
    Here is a useful link
    You don't need all 15, infact soldering all 15 is just about impossible !
    RGB HV and their grounds are all you need. The plug and play data pins (monitor ID bits) are not usually needed for a projector, infact maybe best left out, unless you want windows to take control of refresh rates etc when it finds the projector, IMHO.
    they are connected pin 1-1 , 2-2 , 3-3 etc.
    Good luck with the soldering :)
    Mark.
  6. jackuzi
    jackuzi
    Dec 3, 2001
    255
    16
    South Wales
    Thanks for the feedback peeps.
    Mark - This is exactly the information that I've been looking for, thanks mate.
    Does pin 5 Self Test (TTL Ground) need connecting? only if it doesn't then 9 core cable will do and I might get some from Maplins.
    I do have some of the same cable with 25 core, it's overkill I know but I got it for free :)
    Anyway will give it a go when I get five.
    BTW - Do I need to connect the braid to the D connector case?
    Uzi
  7. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    +171
    Hello Uzi,
    Dont think you need pin 5.
    You ideally need to connect the braiding to the d plug case, otherwise the braiding will not be shielding much, if not grounded.
    Mark.
