DIY sw upgrades
Discussion in 'Arcam Owners' Forum' started by Jim_R, Jan 20, 2005.
Tags:
  1. Jim_R
    Jim_R
    Are most people doing their own sw upgrades at home or taking their kits into a dealer? Has anyone experienced any fatal problems when doing an upgrade at home (i.e. a change which makes the unit permanently inoperable)?
  2. GarethL
    GarethL
    I've performed a s/w update 3 times without problems. The last time I updated it (on the advice of the Arcam technical helpline) it introduced a new error to my system and did not fix the problem. Unless you have a problem, or need a feature introduced in an update, I wouldn't update. If you do have a problem, it might be worth running it past the Arcam helpline to make sure the update you propose will fix your problem.
