DIY Subwoofer cable?
Discussion in 'Cables & Switches' started by @if ®afiq, Jun 26, 2004.
  1. @if ®afiq
    @if ®afiq
    May 31, 2004
    646
    +20
    Are there any DIY cables that can be made for a sub?
    I assume a CAT5 won't do? (I've got plenty left over!)
  2. Zone
    Zone
    Jun 24, 2001
    6,712
    Barnsley
    +2,389
    Just use a decent double screened coax; RG59 or 6.
  3. Wingnut
    Wingnut
    Is it a high level input using a Neutrik connector? If it is I made mine out of CAT5e and it sounds great. I used a variation of the TNT TripleT. This is obviously designed for a Stereo pair so the design needs to be modified slightly.
    The modified sub cable needs three Connections: Left, Right, and Common. Still use 3 pairs of CAT5, but instead of pairing up the coloured and white strands into left and right channels, pair them up so there are 3 connections.
    I can give you some full instructions if you fancy doing it.
  4. @if ®afiq
    @if ®afiq
    May 31, 2004
    646
    +20
    The sub I'm getting is the MS309 (with the premier plus system) - I haven't got a clue about Neutrik :blush:
    Zone: I'll have quick google and see what cables I can find...
    Thanks for the replies :)
  5. @if ®afiq
    @if ®afiq
    May 31, 2004
    646
    +20
    Would I be looking for the lowest loss possible?
    This site seems to have a fair few - the H100 seems to be their best double screened coax..
    or how about these guys who have some RG213 @ £1.20 per meter....
  6. Zone
    Zone
    Jun 24, 2001
    6,712
    Barnsley
    +2,389
    This cable will be fine for your needs and only 49p a meter. :thumbsup:
  7. @if ®afiq
    @if ®afiq
    May 31, 2004
    646
    +20
    What connector do I need for the coax cable?
    Also the MS309 has a Left and Right "In" which do I use?
