DIY Sub Mk.4 RTP-X
Discussion in 'Home Cinema Building DIY' started by ReTrO, Jun 16, 2003.
  1. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    A new subwoofer project coming up very soon.
    Based around a 10" (or maybe 12" if we can fit it in, size and cost wise) driver this will be for Taz himself when my RTP-15 leaves him.
    It's designed to fit within his TV stand featured here.
    This will be the RTP-X.
    Look for more info and designs soon.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    The RTP-X will be using a Peerless XLS-10 driver, inside an enclosure of approximately 1 cubic foot, around 17/18 litres. This will be made from 22mm MDF, with a 30mm MDF front baffle.
    There will be some form of grill fitted to the front is required, and spikes or rubber feet will be fitted to the base, for use with Taz's stand or on a carpet.
    The amplification to be used has yet to be confirmed, but will most probably be a BKElec BSB 100/8, delivering 100w RMS into the 8ohm driver.
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    Pic 1
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    Pic 2
  5. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    Pic 3 : Front baffle
  6. Taz
    Taz
    The finish for this sub will be an expensive real wood veneer, Eucalyptus burr in fact! ;)
    I have managed to purchase some from work :smashin:
    Sample:
  7. Mike Swannick
    Mike Swannick
    Where's the best place for MDF exceeding the standard 18mm available at DIY stores?
  8. themadhippy
    themadhippy
    dont forget the dog repellant coating:D
  9. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    Small design change. Concerning the front baffle.
    The parts have all been cut as I type and they are undergoing the veneer process.
  10. IronGiant
    IronGiant
    Jun 7, 2003
    53,662
    Oxford UK
    +29,703
    So why the change? If it's going in Taz's TV stand the sides
    wouldn't show or would they? Just curious.
    Dave
  11. Taz
    Taz
    To make it future proof... No one would want to buy it 2nd hand if it had edges of mdf showing against such a lovely veneer. And I may at some stage change my TV rack so it needs to look nice if it is ever on show.
    Mike: Sorry, no idea on buying MDF, builders merchants or your local furniture factory may be able to help.
  12. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    Enclosure dimensions:
    340x340x400mm hxwxd
    Excluding grill, amplifier panel and feet.
  13. IronGiant
    IronGiant
    Jun 7, 2003
    53,662
    Oxford UK
    +29,703
    Fair point Taz. After all you and Retro seem to be churning these things out at a rate of knots
    Mike, look in yellow pages for timber merchants, that's where I got mine.
    Dave
  14. IronGiant
    IronGiant
    Jun 7, 2003
    53,662
    Oxford UK
    +29,703
  15. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    Early production pictures:
  16. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    And here:
  17. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    Mike,
    Have a look here http://www.laver.co.uk/
    You can buy MDF sheets up to 60mm thick :)
    That would make a really rigid Sub cabinet :D
    They also do 8x5 sheets as well as the usual 8x4 size.
    Sure I have seen veneered MDF on there before, cannot find it now though.......
    Mark.
  18. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Have you bought the driver and amp yet?
    BK are doing a package deal on the XLS10 and BSB200, which you might as well go for as it works out to only slightly more than if you buy a BSB100 separately: http://www.bkelec.com/diy/xls10.htm
    In a 1ft cu. enclosure the combo really performs!
    MuFu.
  19. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    We noticed that. But Taz is on a very short budget, due to other AV purchases.:D
  20. Taz
    Taz
    :devil: Got me thinking now! :devil:
  21. Taz
    Taz
    WOW!
    has it been 4 months! how time flys!
    About to order the driver and amp in the morn.
    Will keep you all updated!
    :hiya:
  22. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    Looks like RTP back on the road.
    I'll drop by with my RTP work clothes on at the weekend and we'll get stuff done.
  23. Taz
    Taz
    No you wont :( BK have let me down and not delivered...Gutted!
    Will be Monday for delivery now :rolleyes:
  24. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    Booger.
    Oh well, fitted with me "Destroy It Yourself" scheme anyways. I've been helping tidy up the house from yesterdays "Remove the end of a wall" project, whihc created a lot of dust.
    Juts got me JVC SX-21 D-ILA to play with now. Mmmm 1050p.:D
  25. Taz
    Taz
    Just picked up the connectors... Neutrix NL2FC.
  26. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    Juts need some cable now.:D
  27. Taz
    Taz
    Can you belive, that Maplins were out of stock of EVERY type of sheilded cable! :rolleyes:
    Lucky for me I found some in the cupboard! ;)
    All leads and connections now soldered up, just waiting for the driver now!
  28. Taz
    Taz
    :laugh: OOPS! just noticed that I have a bloody great hole in the back of the enclosure! :blush: That was for the amp, but now im using an external amp box I Guess I better get that sorted out pretty quick! :zonked:
  29. Stellavision
    Stellavision
    Apr 7, 2003
    2,251
    Southsea, UK
    +84
    Is the cab joined only with glue or have you used screws?
  30. Taz
    Taz
    Its doweled and glued.. cant be to careful;)
    First picture on pg 2 of this thread and you can see the holes for the dowels.
