DIY Speakers
Discussion in 'Home Cinema Speakers' started by Smokeyone, Jun 19, 2002.
  1. Smokeyone
    Smokeyone
    Jun 19, 2002
    29
    Before splashing out on a new system can anyone advise on DIY speakers. I have read good reports on DIY subwoofer systems but what about the four or is it five other speakers! For an off the shelf speaker package my budget would run to roughly £600. Also could the same set up qualify as Hi Fi for music only.
    All advice appreciated
    Smokeyone
  2. philmate
    philmate
    Nov 6, 2000
    216
    Southend-on-sea
    +4
  3. GaryG
    GaryG
    Take a look here
    www.wilmslow-audio.co.uk
    They have a couple of demo rooms with built versions of just about every kit they make. If you decide to visit allow yourself a good half day to work through their range, you will not be disappointed.
  4. Smokeyone
    Smokeyone
    Jun 19, 2002
    29
    Thank you for the help. I will look into both firms.
    Smokeyone
