DIY Speaker Cabinets
Discussion in 'Home Cinema Building DIY' started by tom_painter85, May 4, 2005.
  1. tom_painter85
    tom_painter85
    Jan 19, 2005
    201
    Exeter
    Hi all
    I'm looking for a cheap solution to mount some 6x9s I'm borrowing into a van. I don't particularly want to cut the van apart just to put the speakers in, and I'm trying to sort this on the smallest budget possible.
    Is there and kind of 'perfect size' cabinet for a driver? I know there's a few programs floating about on the net for stuff like this - if any one has tried these and wants to point me in the right direction that'd be much appreciated.
    Failing that, some formulas including driver size and power/freq. response would be good too.
    I'm not seeking the earth, just a quick fix...perfection will come when I have real money to play with.
    Cheers in advance
    Regards
    Tom
  2. R2D2
    R2D2
    your best bet would be to take a look on www.diyaudio.com they have a section on ICE
