sjackson
So my plan is to build a trio of DIY Sound Group's "The 893" speakers for my front left/centre/right in addition to 4 of their "Volt 8" speakers for surrounds and rears. I currently already have 4 Monitor Audio 265-IDC's in my ceiling for future Atmos duties. Depending on how the Monitor Audios work with the Volt 8's, I may think about replacing them (MA's) with Volt 6's.
I only ordered the kits and I did not buy the flat packs mainly as I felt they would add too much to the overall shipping costs to have them sent over from the USA.
As I don't have the flat packs, I'll call into B&Q and have them cut me up some MDF sheets. I'm aiming to have them as shallow as possible which means I need to build them taller to get the correct volume. With this in mind and the dimensions of an MDF sheet, my speakers will be the below sizes:
First impressions
The 893 baffle is smaller than I expected. Not sure why as I had measured it out a few times prior to ordering. The baffle is really solid and very well cut out. Having a supplied baffle will make this job and awful lot easier.
The Volt 8 baffle was much bigger than I expected and to be honest I think they are too big. I should have bought the Volt 6's as the 8's I'm expecting to be overkill for my smallish room. That said I did read that the 8's were a significant upgrade over the 6's. Maybe I'll change my mind once built but for now I may have made the wrong choice. People who buy the Volt 10's for surrounds in a small room are bat$hit crazy - I'd be afraid they'd blow my head off!
Anyway, the first of hopefully many photos. 4 of the 5 boxes of bits that DHL delivered.
All photos now here: 2015-12-12 - DIYSG Speakers
- 893's - 1224mm tall (full width of an MDF sheet), 260mm wide (width of the supplied baffle) and and around 200mm deep.
- Volt 8's - 611mm tall (half width of MDF sheet), 280mm wide (width of supplied baffle) and around 125mm deep.
First impressions
