DIY Screen
Discussion in 'Home Cinema Building DIY' started by Sorcery, Sep 4, 2003.
  1. Sorcery
    Sorcery
    Dec 12, 2002
    47
    Hi all,
    I am thinking of constructing a screen from a sheet of either MDF or Ply and painting it either with Goo from Goo systems or Dulux IceStorm No.6. I will probably mask off the edges with black tape or similar.
    Firstly do people here think that this would give a decent picture?
    Would it be better to wrap canvas / blackout material around the wood?
    Secondly what is the best way of attaching such a sheet of wood to the wall? Are there brackets that can be bought or is there a cheap and cheerful way? :)
    Cheers,
    Nick
  2. mortonman
    mortonman
    I have just completed a DIY screen and as the wall was perfectly straight it is screwed on but I was also considering mirror brackets that can be found in most hardware stores.
    Matt
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I went the frame plus blackout material painted Icestorm 5.5 ;) route. More info on my screen here - inc what I used to fix it to the wall.
    With the MDF route, unless your wall is dead flat, you'll need a thick piece of timber, and it will be a PIG to get up, as it will be v heavy and unwieldy (IMO). We sat the screen on a stool, fixed the top brackets in place, then removed the stool and fixed the other brackets. As the wall isn't straight, I used some packing to get things perpendicular to the firing line of the PJ.
  4. porker
    porker
    Mar 18, 2002
    263
    Teesside
    +26
    Looks good RichardH, love the wall colour, what is it?
  5. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    It was a B&Q one coat emulsion called (IIRC) Warm Red. They do/did a very similar one that can be used on all surfaces called "Henna".
  6. wb1
    wb1
    Sep 5, 2003
    1,671
    38
    London
    +21
    this all looks really really cool. I bet you and your family are chuffed to bits!
    Sal
  7. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    I have just finished making my new screen :D
    As it's in a smallish room I only wanted it to be fairly small so I just cut it out from a sheet of 18mm MDF...12mm would have done the job but I just happened to have the 18mm sheet spair.
    The screen is approx 53" wide and I applied two coats of MDF primer followed by two coats of Dulux Icestorm 6.
    The MDF sheet is simply screen directly to the wall using a fixing in each of the four corners...thankfully my wall was pretty flat.
    Tommorow I plan to add a frame around the outside of about an inch thick to cover the screw holes...this will be painted black.
    Then I plan to get a thinner sheet of MDF...or maybe ply...to make a cover for the screen which can be hooked over to both cover the screen when not in use and also to allow a poster/mirror/something to tart it up.
    Have tested and the image is on a par with the free screen I got with my PJ...a HS10...and might be slightly better - it's a damn sight flatter and has no wringles :D
    Cheers, Lee
  8. Goof
    Goof
    Oct 14, 2002
    794
    Scotland
    +3
    Having seen Richard's I've decided my screen looks a little lame and unpolished :D
    I went for the blackout material around a hollow wooden frame approach (with thanks to Mr Lightfoot :smashin: ), 92"x54" IIRC but it's lacking the nice black velvet border.
    I'm just wondering if anyone has a good idea of how I could add this to the current construction? Taping round the back would be fine but I'm just wondering how I'd fix it to the front? Some sort of material glue perhaps? Oh, and anyone have a rough idea of how much the velvet will cost?
    TIA and sorry to invade the thread Nick :)
  9. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I was given the velvet, so can't say. What about some spray adhesive? You can get rubber based spray stuff that's pretty strong - not the spraymount used for pictures. Something like this , perhaps?
    I'd test if first, though!! Make sure the velvet isn't marked through, and that it sticks!
    Can you tuck the fabric between frame and screen at the front to finish it off nicely, too?
  10. Goof
    Goof
    Oct 14, 2002
    794
    Scotland
    +3
    Thanks Richard, actually thinking about it, I might get away with PVA! (sorry, recent ex-student and still have to watch the pennies :D ).
    Unfortuntely I won't be able to tuck the velvet between the screen and frame as there isn't a bordering frame, it's just the cloth wrapped around and over the frame. That's why I'm a bit concerned about the finish I'd get...
  11. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Ooooh, it's going to be tricky to get a nice straight edge, isn't it! To be honest I'd consider another solution, as I think the velvet might be a recipe for disaster - I think PVA would soak through into the "pile" of the velvet, too.
  12. Goof
    Goof
    Oct 14, 2002
    794
    Scotland
    +3
    Well, I was only half-serious about the PVA...
    Would like to give the velvet a shot though - if I got some of that spray adhesive and doubled the edges of the velvet over so there are no frayed edges I'd hopefully get away with it!
  13. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Yeah, that should be OK - good idea. What about double sided tape as a less messy alternative? The double sided carpet tape is REALLY strong stuff, and might do a neat job.
  14. Goof
    Goof
    Oct 14, 2002
    794
    Scotland
    +3
    Yeah carpet tape sounds a good idea!
    See, there was you being all pessimistic as well :D
    Thanks Richard.
  15. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Just had some more bright ideas :rolleyes:
    What about buying some velvet ribbon? Don't know if you can get it in 2" wide strips, but it would be nice and easy to apply then...
    Idea number 2 - have some hardboard cut into 2" wide lengths to make a frame round the screen, cover the hardboard in the velvet (easy then to wrap around), then fix it to your current frame. That way it's nice and straight, you get a slight lip for that "picture frame" look.... and errr that's it.
  16. Goof
    Goof
    Oct 14, 2002
    794
    Scotland
    +3
    That is actually a pretty good idea richard, it's either that or I take the current material off, apply velvet around the frame, then stapple the blackout material around the back as you have done.
    Only thing is, I don't think my frame is half as well as constructed as yours! Tbh I think the only thing that's holding the structure is the material's tension :lol:
    So may just get velvet ribbon and another frame...
  17. Sandman
    Sandman
    Nov 28, 2002
    3,566
    Glasgow
    +1,271
    I have just bought my first projecter (panny ptae100) and enjoyed my first night of watching dvd large screen last night. I was watching it on a very flat plastered wall and althought the colour of this wall is not white (it is light terracota) the picture was superb. Anyway I think I will paint a screen sized section of the wall white to make the picture a little brighter. I have a pot of white matt emulsion in the house that I was going to use, will this produce a good finish for projecting a picture on to or should I be using gloss paint? I see that most people use dulux ice-storm paint. Where is this available, I looked in my local b & q but couldnt find it and have also had a look on the dulux website and couldnt see it. Does this go by any other name or am I being stupid?
    p.s. My girlfriend is none to happy about me painting a large white rectangle in the middle of the living room wall, just wait till she finds out that I am going to surround it with a 1.5" thick black border!!
  18. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    USe Matt, not gloss, I'd say.
  19. Mike Swannick
    Mike Swannick
    Icestorm is from the grey range of the Dulux mix centre paints. Homebase do Dulux paint mixing.
