DIY Screen
tomthx
Hi all,
I have had a search through the DIY screen topic, but I would just like to know what is the best side of the 3 pass material to use? The cloth side or the other (rubber type) side?
Thanks, Tom.
PS. I'm using a PT-AE100 in a light controlled room.
C
Cornelius
Not sure what 3 pass material is but if its similar to 'black out' cloth then I would use the white side not the 'off white' rubber side.
CKA.
Peter Parker
I'm using a home made blackout cloth screen, and after trying both sides, I preffered the white cloth side to the off white rubber side.
Gary.
