DIY screen - can you iron blackout cloth?
Discussion in 'Home Cinema Building DIY' started by retrof, Feb 3, 2003.
  1. retrof
    retrof
    Feb 28, 2001
    155
    +14
    Hi - have my frame ready to go, and just need some advice on the blackout cloth. The cloth I got had been folded in places (not creased too badly though), but I'm wary of ironing it even at a low heat. I expect it'll have to be done on the fabric side, as I reckon that vinyl covering will just melt nicely otherwise!.
    Anyone done this or have any advice on taking the creases out of the cloth?
    cheers,
    -rf
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    The creases should come out just by stretching it over the frame - it's quite stretchy, so you shouldn't have to iron it.
    If they don't immediately, they should over time, especialy if the room is warm.
    Gary.
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I did iron mine very gently, from the non-rubbery side. I put it on the floor, with a towel folded double underneath. This was because I had some nasty creases where the lovely stallholder had stuffed it into a bag for me. However, as Gary says, the creases do come out.
    Have a look here for some pics on my screen build - may help?
  4. retrof
    retrof
    Feb 28, 2001
    155
    +14
    Cheers Guys - I tried a little ironging on the edge (through a sheet at low heat, and with the material on the floor. It helped a little - at least enough to ensure that the stretching will all but eliminate it over time.
    Thanks for the help!
    -rf
  5. Jackass
    Jackass
    Jan 9, 2003
    3,045
    +593
    Guys,
    This might be a stupid question but what side are you supposed to project on to? The vinyl or white woven side?
    Yours confused.
    Steve.
  6. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
  7. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    Yup, white woven.
    Of course, you could try both sides as a test before you fit it too the screen just in case you prefer the vinyl side.
    Gary.
  8. adieacc
    adieacc
    Feb 2, 2002
    128
    16
    South Wales
    Just had a similar problem, and discovered that once you have attached the cloth to the frame just steam the cloth, eg use the steam setting on the iron, running the iron over the material but a centimetre or so away (not touching the cloth) and the creases should drop out.
    Adieacc
  9. Jackass
    Jackass
    Jan 9, 2003
    3,045
    +593
    Thanks Guys.
