DIY Screen Advice
Discussion in 'Projectors, Screens & Video Processors' started by slim UK, Aug 29, 2004.
  1. slim UK
    slim UK
    Aug 25, 2004
    16
    I want to make a manual roller projector screen. The roller section will be installed on the side of a window frame and when watching will be pulled across (ie, left to right and hooked on other frame).
    I need to find out where I can order the material with a black border insert (I can then have a screen size suitable for a throw distance of around 3.5m)
    Ian
