DIY SCART to VGA
Discussion in 'Cables & Switches' started by wiredcharlie, Mar 27, 2005.
  1. wiredcharlie
    wiredcharlie
    Mar 3, 2005
    17
    I started reading this thread just before I bought my TH37PW7. I was struck by the almost unanimous recommendation of the JS-Technology SCART to VGA box, in fact I almost decided to buy one! Then I started to look into what this box and other similar products like the SyncBlaster actually do.
    Basically the RGB signals from the SCART just need to be connected directly to the same signal pins on the VGA. ie the video does not need to be changed at all. The Plasma VGA does however require separate Horizontal and Vertical Sync signals.
    So, I started trying to find a simple way to build a Sync Separator for myself.
    The result is a small is this:
    [​IMG]
    It is powered from pin 8 on the SCART - which I expected not to work properly!
    This is my scribbled circuit diagram:
    [​IMG]
    The circuit is based around the Intersil EL1883 IC and more info can be found here:
    http://www.intersil.com/cda/deviceinfo/0,0,EL1883,0.html
    This is quite a new chip and generates proper Horizontal Sync pulses. According to the data sheet it is also Macrovision compatible!
    My only testing has been with a Hauppauge DEC-2000 Freeview box and my Panasonic plasma. Results are perfect!
    If anyone knows a bit about electronics and wants to have a go I would be happy to help.
    Tony
  2. chienmort
    chienmort
    The difference between scart and VGA is that VGA has TTL level (5V high impedance) separate H+V syncs and Scart (RGBs) has composite low impedance (0.3V 75ohm) syncs. So both Keene and JS have a built in sync separator.
    Make sure that your unit can accept video frequencies via VGA before spending or building.
    BTW the circuit looks good!
  3. wiredcharlie
    wiredcharlie
    Mar 3, 2005
    17
    Good point.
    The signal spec will be listed as 625(575)/50i in the Plasma display manual. This means 625 lines (575 visible lines)/ 50hz interlaced. The horizontal (line) frequency is 15.625KHz and the vertical frequency is 50Hz.
    Tony
  4. Vikash
    Vikash
    Mar 27, 2005
    35
    11
    excellent. do you have a larger schematic, and/or component diagram to follow. I'll be giving this a go to get my new PW6 going :smashin:
  5. wiredcharlie
    wiredcharlie
    Mar 3, 2005
    17
    Have a look at this:
    http://www.intersil.com/data/fn/fn7010.pdf
    The only addition I've made is to protect the IC from overvoltage by putting a zenner diode across the supply, plus a 1ohm series resistor.
    If you look at my scribbled circuit, scart pin 19 is shown as S19 etc and D-type pin 13 is D13 etc.
    I suspect the only circuit value that is absolutely critical is the 681K resistor from pin 6 to GND - see the pdf.
    Plug pinnouts here:
    http://www.hardwarebook.net/connector/av/vga15.html
    http://www.hardwarebook.net/connector/av/scart.html
    The IC is a surface mount component. I carfully soldered it to small wires plugged into an ic socket (tricky). Then soldered the ic skt to the scrap of veroboard I built the circuit on.
    Tony
  6. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    765
    Amsterdam
    +13
  7. wiredcharlie
    wiredcharlie
    Mar 3, 2005
    17
    For a mass produced item, yes. For a "Cottage Industry" niche product, maybe not.
    Tony
  8. geewhizz
    geewhizz
    Jan 2, 2005
    2,406
    +84
    So the question is ::: are you going to be selling them ?? :cool:
  9. Vikash
    Vikash
    Mar 27, 2005
    35
    11
    Tony, where did you get the IC's from? I've orded a few samples so let see what happens.
    I'm doing a few kits at the moment, so if this really is as good as the £100+ commercial equivelents, then I see a possibility of getting a kit and PCB's made to sell.
    Here's a mic preamp kit I'm doing at the moment:
    http://www.vikash.info/audio/pim/micpre.asp
  10. Vikash
    Vikash
    Mar 27, 2005
    35
    11
    Hi Tony,
    I've got the chips and will have a go. The PDF mentions RSET as 681K for NTSC. Is this what you used, or did you adjust it for PAL as I assume would be required?
  11. magge
    magge
    This is really interesting compared to the expensive alternatives!!!
    Did you figure out if you infact have to tweak the resistor for PAL? I read the EL1883 specs and I got the impression that the resistor had to be tweaked for different resolutions aswell?
    Is the output of the EL1883 H/V sync in a compatible voltage level for the VGA connector side?
    I'll try building one or more of these if Intersil will give me sample chips. If I can make it work I think this thread has saved me $$$. Great info, thanks! :thumbsup: :)
    ...now all I need is to find a DIY IR repeater kit. :)
  12. dvd_chemist
    dvd_chemist
    my name is David and I'm an electronics complete newby.
    Nonetheless I'd like to build a cable similar (I think) to the one you shown in the thread "DIY SCART to VGA".
    The objective is to use a new LCD monitor (which I still have to by and which probably will be the SyncMaster 2032BW http://www.samsung.com/uk/products/m...0pebsfvedc.asp) to watch dvds from a dvd player (with scart, s-video and rgb outputs).
    Actually I see in the techincal details of the 2032BW monitor, that the accepted "Signal Input Video Signals" are:
    - Analog RGB, DVI
    - Sync. Type Separate H/V, Composite , SOG
    and that the "Input Connectors" are:
    - D-sub, DVI-D
    So I don't really know if I require a sync separator as you put in your cable or if I can simply connect the scart output pins to a VGA pins...
    ... well, I told you, I'm a coplete newby; please, be understanding, I didn't mean to bother you too much.
    I'd be pleased if you could give me some advice on how to obtain what I need...if I managed to explain it...'bout which I'm not really sure...
    Well, if you have some time, I'd really be thankful if you could answer me.
    Thanks in advance anyway.
    David
  13. choddo2006
    choddo2006
    Dec 30, 2005
    8,526
    +544
    If you buy a standard monitor you may well find it cannot accept the horizontal sync frequency of 15.625KHz - the spec will normally state what freq range it can accept over VGA
  14. dvd_chemist
    dvd_chemist
    thanks for your fast reply.
    I'm sorry but I still don't understand well.
    The frequencies in the specifications at this page: http://www.samsung.com/uk/products/monitors/lcd/designer/ls20pebsfvedc.asp
    are:
    Horizontal Frequency(kHz) 30 ~ 81
    Vertical Frequency(Hz) 56 ~ 75
    The 15kHz frequency you mentioned is the normal output from a dvd player?
    What should I do then to see an image from a dvd player on such a monitor?
    Can you please check the specs of the monitor (see link above) and tell me what would you do to be able to see a dvd from a normal dvd player?
    thanks in advance, also for being understanding.
    David
  15. freeman
    freeman
    Dec 27, 2004
    240
    +11
    Don't you need something like this?
  16. dvd_chemist
    dvd_chemist
    Thanks for replying, in fact I do need something like that, at least logically speaking.
    But it cost more than the monitor itself...
    Actually I found a similar device for much less:
    http://www.playtronics.it/product.p...+S-VIDEO+------>+VGA+MONITOR+PC+CRT+LCD~.html
    What I thought, reading this old thread, was that I could build myself a cable doing the conversion with an "enough simple" circuit...
    Unfortunately I wasn't able to contact wiredcharlie, who built something which seemed to me close to my need (cheap and effective selfmade cable).
    Thanks,
    D
  17. ntsc443
    ntsc443
    Sep 8, 2009
    5
    Hello, i want to build scart to vga (or video i think it's simplier) adapter to connect Philips SLV3100 TV link to Home cinema projector. I have made connector, but it worked for about 10 seconds and video disapeared, tryed second time and result was the same. Maybe you have schemes or something, that might help me? I'll be very thankful, Basketball championship has began so, I hope that I can watch these games in my home cinema. I'm from Lithuania
  18. ntsc443
    ntsc443
    Sep 8, 2009
    5
    Deleted
  19. ntsc443
    ntsc443
    Sep 8, 2009
    5
    Sugestions? :confused:
  20. Vikash
    Vikash
    Mar 27, 2005
    35
    11
    Anyone get this working?
  21. ntsc443
    ntsc443
    Sep 8, 2009
    5
    Still in progress...
  22. ntsc443
    ntsc443
    Sep 8, 2009
    5
    Done, but without scart adapter. I just opened AV link box and found, that it receives wireless video and it goes like simple RCA to another converter and then i get Scart. Simply disconnected that converter and got this system running. Now i can wach TV in my home cinema :) :clap:
  23. RascalRuss
    RascalRuss
    Dec 31, 2009
    2
    Hi Guys,
    I know this is a really really old thread now, but does anyone have the wiring diagram for making the JS RGB to VGA project that is discussed??
    Russ
  24. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,327
    +665
    Just for clarity, the JS product is a commercial item, it was mentioned in passing at the start of the thread but the rest has nothing to do with JS.
  25. RascalRuss
    RascalRuss
    Dec 31, 2009
    2
    Yes sorry,I was just refering to JS as the type of box
