Dony
I need to fix a basketball backboard to my garage wall and the mounting bracket and fittings that came with it is next to useless.
I've decided that the easiest way will be to fix wooden batons to the wall and then attach the backboard to the batons.
Can anyone tell me what's the easiest way to do this? Can I simply cut out the batons to the size required and drive them into the block wall using heavy duty nails, or is there some other more reliable way to do this?
My DIY skills are minimal at best, so feel free to call me an idiot provided you tell me the correct way of doing it!
