biggy7
Yeh. Sounds good.
Enjoy
Enjoy
Sounds right mate! The spraying easy just build up the layersPicked the dulux up today and the AAA I had already. So I'm doing 0.5lt to 120 of AAA and 15 percent water yeah?
Spray day tomorrow.....apprehensive but what the hell.
93ml mate.So what's 15 percent water in ml? I'm only used to kg and gr.
But the look of the thread most of the guys here went for grey steel 2 ! PIctures great on my screenHi guys, I currently have a room painted magnolia. No ambient light. Benq w1070 projector. I do eventually plan on blacking out the room, but that's not happening yet and if it does I can repaint the screen wall, so I'm thinking of getting the best results for now with the room the way it is. Grey steel 1?
I'm wishing now that I had went for GS1 as I'm finding the GS2 a bit light for my tastes for daytime viewing.
I'm also starting to realise that the black level in general isn't that great on my rather low end projector the HD141x.
I guess whichever you get, you'll always wonder whether the other might've been better.
Yeah the upgrade bug was always going to be there and is ever present when looking at the forums i find.ohhh, the upgrade bug is kicking in
good thing with GS2 you can easily paint over with GS1, not sure if you went from GS1 to GS2 though, of course will cost the price of the paint, im guessing you only need 500ml Dulux and 1x 120ml AAA, so maybe a cheap solution.
I've had a few, Optoma HD65, Mitsubishi HC3800 and now this Optoma HD141X. Each of these have had their own screen built for them, the HC3800 had an original black widow mix and over 100 inches in size.Ste0803 is that your first projector mate or you been projectoring for a while?
