DIY Projector Lift - Help required
Discussion in 'Home Cinema Building DIY' started by Rob_Quads, May 8, 2005.
  1. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    373
    Chandlers Ford
    +12
    I am in the middle of designing a projector lift which will hide the projector in the ceiling when its not in use. Most of the design is sorted and its all fairly simple stuff - using 5 short drawer runners for the up/down motion with brackets made up to support it all.
    So the problem... Manual or Electric. It would be fairly easy enough to put a catch on it and a handle in the roof to enable it to be pulled down but ideally I would like something that will electrically move the projector down.
    As can be seen in the diagram below I need something with a throw of around 4.5" -> 5" BUT its overall size cannot be much more as this is being designed to sit between the joists and not protude out the floorboard of the room above.
    Any idea what I could use? All the actuators I have seen are all ££££ and also way too long even when closed.
    [​IMG]
    Rob
  2. gil2
    gil2
  3. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    373
    Chandlers Ford
    +12
    That looks like a rather complicated solution. If it can't be done easily and cheaply i will just stick to the manual version :D
  4. gil2
    gil2
    complicated aint the word m8 , jeez my head hurts from just browsing through it , i just though it might give ya some ideas , i have had a look around the net same as you , cant find anything on doing it on the cheap as a diy project , jeez they all want a fortune , i`l ask at work tomorow , see if anyone has any good thoughts
    something that worries me m8 after looking at your drawing again , how are you mounting the drawer runners ? are they gona be packed off the ceiling joists sideways or are you making a housing and then inserting that into the ceiling , its just that your drawing looks like yer sorta balancing the runners on the top of the plasterboard which odviously aint good
  5. gil2
    gil2
    how about a small H to H mount and canterleaving the shelf the projector sits on , that way the constant up down is not putting to much strain on the motor
    H to H mounts are fairly cheap to buy especialy small ones , they normaly run of 12v supplys and are used for moving sat dishes left and right , a bit of imagination maybe and jobs a good un
    just noticed rob , u aint far from me :hiya:
    <opens window and waves>
  6. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    373
    Chandlers Ford
    +12
    Whats a H-H mount?
    Ideally just something that could turn a horizontal motion from something like a linear actuator to a vertical motion is all i need
  7. gil2
    gil2
    http://sms.sshost.co.uk/section.php?43
    this is a H to H mount m8 , it has a motor and tube that turns , the dish is mounted on the tube normaly for left and right movement , but if u where to mount it horizontaly and connect the tube to the shelf somehow you would get up and down movement , also if u click on positioner on the left hand column of the site i gave there , that connects to the mount and will move the tube on the h to h mount by the desired amount set with the positioner , they can be remotely controlled as well , worth looking into i`d say
    thats it m8 , thats all i can come up with
  8. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    373
    Chandlers Ford
    +12
    After thinking some more about this I think I have given up the completely automatic idea but I am thinking along the lines of...
    The projector will be held up by a latch which can be released by a 12v solenoid - this can easilly be wired up remotely (I do it in cars all the time so know it well). This would then drop the projector when required. It would obviously need to be pushed shut but thats fine as it means there is no external 'handle' required to pull it down.
    The only problem with this design is it will come down with a bang without any dampening so i need to work out how to dampen the runners so that it moves slowly when released.
  9. sjl
    sjl
    Jan 1, 2001
    81
    I know this thread is relatively old as the forum gets lots of new posts very quickly but just a suggestion if you are still struggling.
    Use some gas struts from a car tailgate.They will give you the damped effect you want and are relatively easily mounted and as a bonus are quite slimline so will probably tuck away quite easily.
    Might be worth having a dig around a scrapyard for a few hours with a tape maeasure to see if it feasible.
    Steve
  10. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    373
    Chandlers Ford
    +12
    I do like the idea - having done a lot of work modifying cars I thought about this option but unfortunatly bonnet struts are just too strong. If you have ever had a set off a car they are near impossible to close by hand. The main reason they are easy to close on a car is due to bonnet/tailgate weight and pivot points.
  11. kez
    kez
    Jan 18, 2002
    7,791
    Leeds, West Yorkshire
    +969
    saxo, by any chance?
    :hiya:
    kez from SSC :)
  12. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    373
    Chandlers Ford
    +12
    lol [​IMG]
  13. IronGiant
    IronGiant
    Jun 7, 2003
    54,134
    Oxford UK
    +30,129
    Don't hold your breath, but many years ago I picked up a pair of tiny gas struts that were being chucked out at work, Why?... because I thought they must be useful for something. :rotfl: It was probably 15 years ago.
    If I recall correctly they were about 6" long compressed and held/damped a 1/4" thick perspex lid about 3 foot by 1 foot. Might be just what you need. I'll see if I can find them. Can't guarantee anything, but you're welcome to have them.
    Caveat, if I can find them...
    Dave
  14. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    373
    Chandlers Ford
    +12
    That sounds perfect. Had not seen any that short
  15. cowtipper
    cowtipper
    Jan 29, 2004
    164
    19
    how about utilising a Linear Acutator
    I have been thinking about the same thing for a while now and the only way i could think about retracting the mount was utilising an actuator
  16. cowtipper
    cowtipper
    Jan 29, 2004
    164
    19
  17. IronGiant
    IronGiant
    Jun 7, 2003
    54,134
    Oxford UK
    +30,129
    Looks good, might do the job for you.
    Had a look but couldn't find those baby gas struts.
    Dave
  18. Rob_Quads
    Rob_Quads
    Feb 14, 2004
    373
    Chandlers Ford
    +12
    Bugger - that would have been perfect.
  19. IronGiant
    IronGiant
    Jun 7, 2003
    54,134
    Oxford UK
    +30,129
  20. davehk
    davehk
    Oct 17, 2003
    702
    28
    London
    +45
    RS components have a range of adjustable pressure gas struts
