Chrisoldinho
I've ressurected my old PC, a 2.2Ghz (overclocked to 2.4 - will detune again as stability is more important than performance here) with 512MB SD RAM PC133 and 2x 40GB ATA100 HDD's ( one of the HDD's has an error on it at about 35GB so I can only partition the first 34GB ish before it goes wrong
) - But they are both identical so I was considering some form of RAID array on them. It also has a 10/100 NIC. I sold the dedicated graphics card as it's not any use on this project.
I'm going to install FreeNAS on it as that seems ideal, but I have one BIG hitch.
The case, it's just too big. I'm wanting to put my newly created NAS in a Cabinet and the dimensions of the case are both too high and deep.
Can anyone recommend a dirt cheap (otherwise not worthwhile) Mini Chassis (no more than 35cm high, 25cm deep including the power cable)? I have about 45cm to play with in width so ideally a Horizontal case would be the best bet I think, somekind of mini horizontal case. Donations gladly accepted
I don't want to spend £60 on a basic NAS when all I need is a smaller case.
If it's possible to connect the NAS to the Router Wirelessly I have a Wireless NIC and would be happy to do this at the expense of performance.
Thanks for any help, Chris.
