Stephen Neal
I finally got fed up with the poor quality iMon displays in my Antec Fusion cases, and did a bit of research for replacements. Nothing really seemed quite right.
So I've had a go at building my own. So far, so good. Nowhere near finished - but as a proof of concept it's working, with a backlit 2x16 character LCD at the moment, but I've got some OLED equivalent displays in the post (I hope!)
After a bit of digging it appears that LCD Writer is a decent Media Center plug-in (which replaces Frontview), and it can use any display that is supported by LCDSmartie (which is a lot of displays)
I also discovered people were using Arduinos (cheap, easy-to-program tiny computers with lots of I/O and on most models a built in USB interface) to talk to LCDs, and someone had written some code to emulate a Matrix Orbital display (which LCD Smartie supports)
So I thought LCD/OLED + Arduino (emulating Matrix Orbital display) + LCD Writer with the LCD Smartie Matrix Orbital driver might be a solution.
And it works.
It's a bit Heath Robinson at the moment - (the Arduino and LCD are on a breadboard) but I hope to engineer a neater solution (Arduino Nano + OLED display + Micro USB B plug to motherboard USB header) I might even see if I can make it fit in the same packaging as the iMon!
If anyone's interested I'll put up some pix and links. None of this offers any Infra Red remote control - but I've always wanted to disable the IR receiver on my iMon as I use standard Microsoft eHome receivers (or OEM variants). Might buy a Maplin one and see if I can dismantle it and mount it internally?
And it works.
