DIY - Interconnects
Discussion in 'Home Cinema Building DIY' started by CodeThief, Jul 2, 2002.
  1. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Anyone made any???
    Im trying to make some from www.tnt-audio.com but I can't find this Wire-wrap they're talking about using. Has anyone made any and can they recommend some good instructions??
    Dave
  2. banners
    banners
    Jun 26, 2002
    473
    nottingham
    +16
    i have made the described cable. got the wire wrap from Radio Spares. they only serve to companies and not joe publc though which could be a bit of a downer. not sure of any where else that sells the stuff now maplins have stopped selling it. :( imo they are worth the effort if you can find the wire wrap, as in my system they sound pretty good:rolleyes:
  3. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Thanks the reply.
    Bum. Don't suppose you have any spare do you??
    Dave
  4. KW1816
    KW1816
    Jun 14, 2002
    836
    Surrey
    +14
    Banners,
    By 'Radio Spares' do you mean RS ?? I know they only used to take orders from companies but I thought anyone could order from their website
    http://www.rswww.com/
    Could have sworn I ordered something from them a couple of months ago !
  5. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    DOH!
    Of course, I didnt think of them. I've just had a quick search and can't find anything though. Anyone got any ideas what I should be searching for?? got a product code at all???
    Dave
  6. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Royal County Of Berks...
    Some wire wrap here!
    Wow! I registered just to say that!!!
    Oh! Any one can buy from RS.
    There is a cost difference if you buy via your employers account.
    (maybe shipping?);)
  7. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Thanks,
    I feel priviledged you registered for that ;)
    Sorry to say that link doesnt work. At least I know it's there though. I'm off to search :)
    Thanks again
    Dave
  8. kevenh
    kevenh
    Jul 3, 2002
    342
    19
  9. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    woohoo :)
    That one worked :)
    Is it specifically the Kynar wrapping wire, is that the right one??
    Dave
  10. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    Dave, which cable at that site are you making?
    Either wire wrap shown should be OK.
    Have you any tools to make using wire wrap easier?
    The kynar one may need a special tool.
    The Tefzel® Insulated Wrapping Wire looks the more usual wire wrap type.
    I haven't used wire wrap for ages but the tools only make it easier. If you're just making one cable, pliers or tweezers could be a work around.
  11. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Im gonna make the first one on this page ... http://www.tnt-audio.com/clinica/diyce.html . You need the wirewrap to insert through the satellite cable insulation. Do I need special tools to do something with it then??
    Dave
  12. kevenh
    kevenh
    Jul 3, 2002
    342
    19
    OK!
    That cable just needs the 'thin' cable characteristic that wire wrap cable has by default.
    i.e. there's no actual wire wrapping going on - no special tools required!!
  13. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Thanks Kevenh :) ,
    banners,
    You said that you made this. What did you do about the little RFI box he talks about (and gives no instructions for). did you omit this or use something else???
    thanks
    Dave
  14. banners
    banners
    Jun 26, 2002
    473
    nottingham
    +16
    first, sorry about starting a new thread oops. i made the x1.5 cables. i didnt use a rfi box, i think it's just a ferrite ring / box assembly. if you have problems acquiring the wire wrap i think i may have some left some where.
  15. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Hi :)
    So I guess that you just joined the ring on both RCAs together using one of the wires??? ie one piece of wire wrap for the center pins and the other for the outer rings??
    Thanks.
    Dave
  16. banners
    banners
    Jun 26, 2002
    473
    nottingham
    +16
    i connected the 6 red to the centre and the 6 white to the ground. insulated the two with ptfe tape and also wrapped the assembly with the ptfe
  17. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    I've just made a pair using different instructions (http://www.clefmusic.freeserve.co.uk/audio.htm). At first they sounded really bright but after an hour or so they're settling down. I'll post pictures tomorrow. (I think they look really cool :)
    Dave
  18. banners
    banners
    Jun 26, 2002
    473
    nottingham
    +16
    might be interested in knocking a pair up my self. may be at the weekend. it would be good to compare them to the x1.5's and the other cables i've made. could you let me know if the performance is worth it, and also compared to what?
  19. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    lol,
    These are the first I/C cables I've made so I can only compare them to the ****ty thin things that come with CD-Players :) They sound a bit better to my ears but I haven't really done much of a test. I'll test them properly when my Q1s eventually turn up :)
    Dave
  20. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    btw, you said join the 6 cables up in your previous post, uh what 6 cables?? have I been reading a different set of X1.5 instructions to you??
    Dave
  21. banners
    banners
    Jun 26, 2002
    473
    nottingham
    +16
    www.tnt-audio.com/clinica/diyce.html . dave try this for clarification. here it is under the heading of "it is number 2 - look how twisted he is". in other pages it is referred to as the x1.5. the only difference is i used red kynar as opposed to red + black for the signal and white for the ground.
  22. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Aaah thanks mate. I thought the x1.5 was the first and the X3.0 was the second. Must read things more clearly :) Think I'll make these tomorrow :)
    Dave
  23. banners
    banners
    Jun 26, 2002
    473
    nottingham
    +16
    good luck! i found it helped to superglue the start and also periodically along the length just to keep sections in place. perseverence is required when stripping the kynar, it is just plain hard work. steve
  24. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Thanks. I can see it now "Man dies in freak superglue kynar accident!!". I have a bit of a clumsyness with superglue :)
    Dave
  25. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Heres some pics of my cable bodges so far :D
    First up, the unterminated Cat5 cable
  26. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Then the Interconnects :)
    Dave
  27. banners
    banners
    Jun 26, 2002
    473
    nottingham
    +16
    dave , your cables look pretty good. pity they're around the back eh? any way built the cables in your link earlier, they don't sound too bad. a little splashy in the treble maybe, but that may tame itself over the next few days. just as a matter of interest, where did you purchase your phono plugs?
    cheers steven
  28. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Yeah the treble's a little harsh to start with but calms down and I think they sound good. Well, a damn sight better than those ****ty things that came with the CD player :) I got the phono plugs from Rapid Electronics. They're my local electronics supplier. They do have a website but you need to know the codes, which were .... 20-1260 for the red @ £0.69 each and 20-1265 for black @ £0.69 each. The website is www.rapidelectronics.co.uk. BTW, did you cover the cables with some sort of mesh like I did, or leave them showing. I thought they looked cool, but better with the mesh :)
    Dave
  29. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    the cat5 is now terminated and looks lots nicer :) I'm still considering covering the end of the plug and the wire with heatshrink, waddya reckon??
    Dave
  30. banners
    banners
    Jun 26, 2002
    473
    nottingham
    +16
    thanks for the link dave. i'll try that one later!. didn't cover mine with any mesh. they look better with, but we're here for the sound at the end of the day and it makes no difference in that respect. mesh helps to disguise your cables and with heatshrink gives a professional look. it also makes your diy cables look mega expensive. had a quick listen to the i/c this morning, sounding pretty good so far!
    cheers steven
