DIY Installation - Data Cable
Discussion in 'Projectors, Screens & Video Processors' started by kensden, Oct 19, 2001.
  1. kensden
    kensden
    HC Newbie.
    I am using my work's data projector prior to purchasing my own. What sort of cable should I run from the projector to my AV amp?
    Composite, S-Video, RGB, all of the above. Is there a 10m "off the shelf" multi-core cable terminated in all of the above?
