Diy Heavan
Discussion in 'Home Cinema Building DIY' started by hornydragon, May 18, 2002.
  1. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Vey usefull site.
    Gave me the ideas for mt stands.
    Also made some of their power cables.
  3. Guest
    Hi There,
    I have made up all my main speaker cable from Cat 5E cable, using the twisted twin method, these are 8m runs, there is only one problem to this method is that it does take about 3 hours work per cable, including plaiting the cables, shrink rapping the ends, and silver soldering the ends. I have not had the chance yet to hear the results, as I am still converting my loft to a Home cinema.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Let me know what they sound like as I am well tempted, fancy a bit of DIY over the summer.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    For anyone looking to make speaker cable as shown http://www.tnt-audio.com/clinica/tweaks.html in Cat 5E unshielded 4 pair twisted cable 24AWG non plenum horizontal (solid conductor) 305m in easy pull box, outer sheath metre marked with rip cord (305m version only) ANSI/EIA/TIA - 568-A-5, ISO/IEC - 11801/BS EN 50173, UL444, UL1581, UL1666 Approved.
    £32.90 From
    http://www.screwfix.com/
    Noe that will make some long runs.
    PS how do you get all that copper into a bannana plug? Any insight appreciated.
  6. Guest
    Hi There,
    I used the same cat5e cable from screwfix, and I have used Vann damme banana plugs from vdctrading.com, and they are perfect.
  7. silver_sam
    silver_sam
    The Cat5e is £17.50 for 100m from http://www.screwfix.com/
    I searched "Cat5e" in above link. Some results appeared include below:
    PRODUCT INFORMATION: Cat5e 4pr Utp Cable 100m
    Cat 5E unshielded 4 pair twisted cable 24AWG non plenum horizontal (solid conductor) 100m shrink wrapped. Outer sheath metre marked with rip cord (305m version only) ANSI/EIA/TIA - 568-A-5, ISO/IEC - 11801/BS EN 50173, UL444, UL1581, UL1666 Approved.
    PRODUCT DESCRIPTION UNIT PACKS ORDER QUANTITY
    - 0467 CAT5E 4PR UTP CABLE 100M EACH 1
    £17.50
    Correct me if i am wrong. Can i use this (CHEAPER here £17.50) instead of getting one from Maplin (£30)?
    Also, question on connection to the tweeter from http://www.tnt-audio.com/clinica/ffrc_e.html
    "The remaining cable in our assembly is used for the tweeter connection.
    All white plus coloured ring wires are connected together for the (+) connection to the tweeter and all coloured wires as (-) connection."
    Where are the <<coloured ring wires>> as stated?
    I have seen pic of the cable. I can see the four pairs of conductors. Each white wire is paired with coloured. However I couldn't work out where coloured ring wires are.
    Thanks in advance.
    Silver_Sam
  8. evildonut
    evildonut
    Jan 21, 2002
    91
    9
    Ecosse
