DIY glass shelf replacement
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by cygnusx04, Jan 22, 2008.
  1. cygnusx04
    cygnusx04
    Jan 17, 2007
    534
    South East
    +36
    I have an alphastyle 2 shelf glass stand from Tesco and has the built in cable management tube at the back.
    It's great, but now i'd like to add another shelf between lower and middle shelf.
    Where can i get the glass from? It won't have much weight on, so doesn't neccessarily need to be tempered glass. However i need the edges burred off and rounded.
    Can i buy glass like this? If so where?
    I will just cut notches in the stand legs and slot the new shelf in.
    The alternative approach is to just put riser blocks on existing equipment to raise new XBOX above media center, but i'd rather get a new glass shelf.
    cheers
  2. qwerty1234
    qwerty1234
    Aug 21, 2006
    608
    28
    HERTFORDSHIRE
    +53
    brave move. if you're going to do it I'd definately use safety glass.
  3. s_tether
    s_tether
    Jan 18, 2003
    201
    Hull
    +9
    I did this with a similar unit. Just bought 2 and put them together. got 1 spare shelf now in case I break one.
