DIY: Door rubbing against lock-side jamb with new latch
Discussion in 'General Chat' started by sergiup, Feb 16, 2018.
Tags:
  1. sergiup
    sergiup
    Apr 29, 2008
    7,736
    SE London
    +4,126
    I'm trying to use the right terminology - watch me fail...
    I have a wooden door & frame which required a replacement of its (standard, Yale) night latch. This also meant replacing the keep. Now, the previous keep was held in place with two pretty small screws. With the new keep, I did the alleged right thing and tried to use the four much sturdier screws - only to find the door jamb starting to curve inwards. As far as I can see, the lock-side jamb / frame is too shallow and I might be hitting the wall, and I would either have to use shorter screws, or pre-drill through it, into the wall, and fit the keep with possibly even longer screws with wall plugs pushed all the way through, into the wall.
    I now also have to sand down the parts of the jamb/frame that are now rubbing against the door, unless the trick of fitting the keep with long screws and wall plugs compresses it back into place (we're only talking about 1-1.5mm deflection).
    Does this sound right? Would anyone (with far more experience) suggest anything else?
    Thank you! :thumbsup:
  2. IronGiant
    IronGiant
    Jun 7, 2003
    65,081
    +44,752
    Remove the screws and see if the door jamb springs back into place. If it does, cut a few mm off the end of the screws with a hacksaw and re-insert them. You should have used screws that were shorter than the depth of the jamb, but I wouldn't replace the screws now you have cut a thread with these ones, just cut off the extra length.
    • Like Like x 1
    • Agree Agree x 1
    • List
  3. rampant
    rampant
    Apr 24, 2006
    2,261
    116
    Sarf est near londoninium
    +885
  4. sergiup
    sergiup
    Apr 29, 2008
    7,736
    SE London
    +4,126
    Thanks; I've tried removing them and annoyingly it doesn't spring back into place, even with gentle persuasion from a rubber mallet - hence the idea to just sand it down a bit in the couple of places where it's rubbing...
  5. ThuGLy
    ThuGLy
    Jan 2, 2009
    3,000
    +1,684
    Dyi! Dare you interfere!
  6. John
    John
    Dec 13, 2002
    11,565
    +3,214
    Sorry, I can't get beyond the first sentence :rotfl::rotfl::rotfl:
  7. sergiup
    sergiup
    Apr 29, 2008
    7,736
    SE London
    +4,126
    Haha! Can't believe it took me two days to realise I'd mis-spelled that...
  8. sergiup
    sergiup
    Apr 29, 2008
    7,736
    SE London
    +4,126
    Sorted by employing the Mouse sander for a couple of vigorous minutes, no more rubbing. Door frame/jamb reinforcement will have to be a different project.
