DIY diffusers...?
Discussion in 'Home Cinema Building DIY' started by NicolasB, Nov 26, 2003.
  1. NicolasB
    NicolasB
    Oct 3, 2002
    5,804
    Emily's Shop
    +520
    There has been some talk in the past about somewhat-less-expensive-than-Auralex options for acoustic absorbers. For example, Rockwool slabs compare quite well to Auralex pyramids or wedges in terms of sound absorption, but cost substantially less.
    What would be a cheap, DIY equivalent to Auralex's diffusion-based products (or similar)?
    How about a solution based on egg boxes and lego bricks? :)
  2. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
  3. avanzato
    avanzato
    Jan 21, 2003
    1,874
    Norfolk
    +60
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Why not try vacuum forming plastic over a wooden template?
  5. NicolasB
    NicolasB
    Oct 3, 2002
    5,804
    Emily's Shop
    +520
    Any thoughts on diffusers that work at bass-frequencies? Or is this not technically feasible?
  6. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,150
    Surrey. UK.
    +1,956
    Hi Nic,
    how did you get on with the rockwool project you were doing? What results did you get (or was it someone else?)
    Gary.
  7. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    For bass,things like ASC's Tube Traps are most effective,acting as quarter-wave traps.....there are plenty of designs for homemade versions,and relatively easy to make,but not exactly unobtrusive.
  8. avanzato
    avanzato
    Jan 21, 2003
    1,874
    Norfolk
    +60
    Someone over at Zerogain had a Sound Consultant install eight, 1.3 metre tall, 10cm diameter, 'rubber bung tuned' cardboard tubes to tame the bass. Sounded to me like the Room lens concept.
    The cuved surface should give some HF diffusion so several stacked next to each other might be interesting to try. Cardboard tubes aren't expensive and there'd be little or no DIY involved.
  9. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    It's a pity that good affordable DSP based solutions to room/speaker interactions are only just becoming available,as it will eventually do away with needing room treatments +/- bass traps etc.
    Certainly had something like that been available a few yrs ago when I moved house,I'd probably not have sold the Linn Keltiks I had at that time.
  10. NicolasB
    NicolasB
    Oct 3, 2002
    5,804
    Emily's Shop
    +520
    Hasn't even got off the ground. Probably never will. :(
    I rather doubt that. In the first place there are directional issues. You may well be able to make a direct sound resemble a reflected sound by playing about with delays and phase changes but it's difficult to see how you could completely simulate (or cancel out) the directional aspect of a reflected sound, as speakers are too close to being point sources - I don't see how you could, purely by electronic means, change the overall shape of the wave front across the room accurately enough.
    On top of that, even if a sufficiently ingenious DSP solution could completely compensate for room effects at one particular point within the room, I can't see that there's any way to make it work at all points in the room. Even something as simple as an axial standing wave produces nodes and anti-nodes - unless there is some way to prevent the standing wave from being set up in the first place, I don't see how a solution that produces an accurate frequency response at a node can produce a similarly accurate one at an antinode.
  11. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
