K
kiranp
hi, i have a seperate amp and use it for considerate amounts of time. The problem is that it heats up alot and the air around the heat sink is not circulating. So i wndered if there was a solution to cool down the unit myself using a pc fan mounted on top of the case.
I found this pic of this idea being used CLICK HERE
Please tell me if this method is safe, if so how would i connect a normall PC fan to the mains or any other source around a amp. Or any other suggestions would be helpfull!
thanks alot!
(BTW i have a YAMAHA RX V592 rds Amplifier )
thanks alot!
