DIY cable shielding?
Discussion in 'Cables & Switches' started by minimal_fuss, Aug 19, 2005.
  1. minimal_fuss
    minimal_fuss
    Jun 24, 2005
    222
    Norwich
    Hi, i was wondering if DIY cable sheilding would actually benefit my cables in anyway?
    My stack system runs next to my TV and PC, with all the power cables and plugs for everything about a meter below them. This no doubt generates a little interferance and white noise.
    I was thinking of wraping the cables in foil and chicken mesh secured by zip ties, would this kind of shielding have any benefit? or am i barking up the wrong tree?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Why should it ? :confused: Your input cables are already shielded.
  3. dodgyd
    dodgyd
    Jul 8, 2005
    839
    +71
    One of these might come in handy.
    [​IMG]
    You don't want those stray signals messing with your mind.
    Dave.
  4. minimal_fuss
    minimal_fuss
    Jun 24, 2005
    222
    Norwich
    turns out u guys were wrong :hiya:
    Asked some professionals:
    "What your essentually creating is a faradays cage arround the cables. These are VERY affective at stopping EMF emminating from the cables and thus reducing interferance.
    Chicken wire would work but tin foil is easier to wrap round the cables. Make sure that there are no rips in the foil and that one end is connected to the earth pin in your plug (top pin in UK power plugs). Thats the only requirement for it to work and as long as the foil dosent have any breaks in the length of the cable that will reduce the EMF from the power cables.
    The white noise in the 50Hz range will be reduced as that is the frequency that the UK mains runs at. To save on time you can wrapp all the power cords together but make sure that wires that have different data streams running down them do not get wrapped together (i.e. ethernet with audio)
    Hope this helps."
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    A cage like that will only work if it's connected to earth as you mention.
    Nobody said such a contraption wouldn't work although I'm not sure you really know what you're trying to prevent or why it might be necessary. :)
  6. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Minimal Fuss,
    You could certainly do it. It wouldn't hurt anything. Whether or not you notice any difference is a different matter......
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    wrong? perhaps you should measure the interference first? A mouse cage is only any good if you have mice to keep in it, otherwise it is useless. :)
