DIY cable covering
Discussion in 'Home Cinema Building DIY' started by Nic Rhodes, Dec 13, 2003.
  1. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I need to disguise some new proto type mains cables under a 'sheaf'. Can anyone recommend a system that would hide things from prying eyes but still look good. It is not for a commercial product but just to make sure testing is done ‘blind’. It needs to be able to take a variety of 'variations'.
  2. IronGiant
    IronGiant
    Jun 7, 2003
    62,147
    Oxford UK
    +39,114
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Or what about some of that braided sleeving, perhaps heatshrunk into place at either end?
  4. Jason S
    Jason S
    I've used RichardH's method with some success, although to completely disguise the cable underneath I put an additional layer of maplin heatshrink on underneath the braiding.
    I then marked each cable with a piece of insulation tape, then handed them over to my tester.
    Now waiting to get them back after Xmas with the results...
