DIY Analogue Interconnects Copper
Discussion in 'Home Cinema Building DIY' started by StooMonster, Mar 11, 2003.
  1. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    I'm looking to upgrade the interconnects between my AV processor and amps; currently I have five Linn interconnects.
    I wonder if it's possible to beat the Linn interconnects using DIY recipies and materials?
    Recon I'll use Eichmann Bullet plugs for temination, although could be persuaded otherwise. Any suggestion for cable?
    StooMonster
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,011
    +2,808
    The Linn standard interconnects are actually very good believe it or not. Open them up and check the cable relief clamps aren't crushing the cable as this affects their audio quality.
    I would guess that you could probably create better sounding analogue lead with them or from alternative cabling.
    Gordon
  3. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Cheers Gordon, I will check this; fixing what one has is even cheaper than DIY!
    I am thinking of replacing them, as when I test them with CD player the mid-range is very subdued; perhaps this is caused by the problem you suggest?
    StooMonster
