Divx/Xvid DVD
W
Welshman
My Medion divx dvd player recently died after 9 months of loyal service (trapping my Bourne Supremacy Region 3 : ( , so im looking for a replacement. Does anyone have any suggestions, i need Yuv prog scan output and optical sound output. Currently being suggested are Tosh SD340, JVC XVNP10 and Tangent D400.
F
Fluffy_Engineer
Philips DVP720SA for £85 from Pixmania looks good value
wackyraces
If your looking for a cheap player, the Cello DVD-8105 from Sainsburys is good value at £35. Plays Divx/Xvid etc. It is DTS as well, even though it doesn't say it on the box.
KraGorn
I suspect you mean it simply passes whatever encoded audio it extracts from the MEPG stream out via S/PDIF, for that price it can't have a DTS decoder, surely?
wackyraces
It doesn't have a DTS decoder as far as I am aware. The manual does say DTS/AC3 5.1 decoder but I don't know. It does have a DD 5.1 decoder. If you select DTS on the DVD, then it lights up DTS on the front of the player. I have mine running through my receiver.
Podcast: LCD TVs for Movies, Physical Discs?, RIP Ennio Morricone, AV & Movie news, B+W Matt Damon
