Divx + Software
scrapbook
Does anyone have any experience with this software?
http://www.divx.com/en/software/divx-plus
I have ripped some DVD's using Make MKV and was hoping to convert them to Divx HD but this software tells me it doesnt support this file format (MKV) when I try and add it to the converter
Cieran
Yeah it's crap :D
Just my experience but I couldn't get it convert a mp4 to divx after multiple attempts. I even tried earlier versions and still did not have any joy. Pretty badly supported as well so stay clear if possible.
I ended up using Convert XtoDVD which is a decent simple workaround....
Matt_C
Handbrake doesn't do .avi (xvid/divx) tho, if the OP needs that codec/container for a smartTV or media player. So other than acting as an inbetween - converting the MPEG4 .mkv generated from MakeMKV to a h264 .mkv which can then be converted to a divx/xvid .avi - it's not a lot of use (in this case, if this is the case)
scrapbook
It is the case.
So what is the best method to go from DVD or mkv to divx HD?
next010
It is the case.
Use Staxrip if you want an actual DivX Plus (H.264/MKV) profile but using x264 instead to convert the media.
Staxrip is actually designed for the output of MakeMKV and has a DivX Plus profile built in, plus works with most media types.
The DivX H.264 format is really just High Profile 4.0 H.264 video + AAC audio in an MKV container so anything that generates that should in theory play.
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
